Discussion Starter
jacob j.
Only the weird
1:20 AM
Coastal Oregon
There was a local builder here who was angling his upper transfers in a similar fashion, and there's one for sure in Idaho currently doing it.
Are any of the OPE builders dressing their upper transfers in this way?
3:20 AM
Thanks for sharing Randy....a couple things stand out when looking at this cylinder.
1) Staggered opening of the transfers with the intake side opening first. - would tend to help lift the charge upward
2) Upper transfer roof angle seems to point upward quite a bit - also would would push the charge upward
3) upper transfer height relative to the exhaust seems kinda low suggesting a good amount of blowdown...maybe it isn't as I'm not used to looking at a cylinder like this.
4) tapered squish band most likely employed to help push the charge upward toward the spark plug in the chamber
All this seems to point toward trying to make the engine produce power at a higher RPM vs. being a torque monster....at least that is how I would interpret what I am seeing.
I'm kinda surprised at the cross section of the intake port....near the boot it looks huge!
Kinda cool seeing it this way huh?
srcarr52
4:20 AM
Iowa City
No, I've had the best luck with the exact opposite.
farminkarman
I like the red & black ones
3:20 AM
Neenah Wisconsin
Opening the intake side of the upper transfers first doesn’t make sense to me. On the other hand, making the transfer roof blow upward can certainly help pick up some rpm, but at the expense of some low end grunt.
Ketchup
Epoxy member
2:20 AM
Colorado
Aren’t 500i and 661 transfers sloped upward toward the intake?
HYPERSAWS
West coast cutter
1:20 AM
Oregon
Looks like they are trying for good scavenging and a little more rpm
CR888
6:20 PM
Australia
Well the duration of the transfer opening gets extended with an angled port, perhaps also controls the charge entering chamber in a more orderly fashion. Nice job of slicing the cylinder, so this is quite a way into the 066/660 series being an early MS660. I imagine many designs and changes were made in this series.
Funky sawman
Pony Power
1:20 AM
North idaho
I know Dean at Washington hot saws did that style of transfer ports on my 372xpg. I think Jason Egan is doing it too if I recall
