bikemike
- 8:16 AM
- Feb 4, 2016
- Cottage grove mn
Use it
I'm not an expert on this, but will throw out my humble opinion for discussion . . .What is the difference between an oil seal leaking and a decomp leaking?
Compression release is on the pressure side note the vacuum.What is the difference between an oil seal leaking and a decomp leaking? Many more oil seals lead to scored cylinders than decomps. I'm with Ride Red. I use it for the convienience just as much as for wear and tear. And if it doesnt make a difference on my TM 066 because the button pops almost as soon as I start pulling pulling the cord, so be it. Then its for the psychological factor!!!!
I just read through the rest of this thread. Some guys are worrying about LEAKING de-comps.
OK, I remember an article I wrote for a motorcycle magazine on IDENTIFYING THE PROBLEM. It started out with a guy I ran into that had broken off his clutch lever. I noticed that the mount was absolutely tight on the handle bar. I asked him why he didn't loosen the mount a bit so the mount could shift instead of the lever breaking = his reply - because the mount kept loosening up while he was riding.
I explained to him that that was a DIFFERENT PROBLEM, that was the problem of LOOSE BOLTS. You could fix that problem with lock nuts, lock washers, star washers, Loctite, tie wire - just set it up so that the bolt didn't work loose under vibration. - big DUH!
So why doesn't the de-comp seal. Maybe it needs some WD-40 flushed through it every now and then, along with twisting the valve back and forth to clean up the seat. Perhaps it was defective from the factory and need a bit of lapping with some light valve grinding compound.
If the de-comp is leaking, that's the problem that needs to be fixed.
I've read where some guys were saying a leaking de-comp could LEAN out the mixture. Come on guys, the intake is in the crankcase. The only leaking your are going to get from a de-comp will be COMPRESSION. It won't lean out the mixture at all.
Do your arms look anything like Randy's legs?
Can you elaborate a bit on the differences?Yes!!!!
