Cutting squish band
Nc grease monkey
5:33 AM
Boone, nc
Im curious as to how y'all cut squish band. If dome piston do you try to match the cylinder to the piston? Working on building a squish band cutter and trying to decide on using tool steel or a carbide insert, or custom make an insert
Deets066
AKA Deetsey
5:33 AM
HSS works pretty good
Termitebuffet
Home of the corn can muffler .....
5:33 AM
Midgetville Norf Kacolacky
I cut mine on a lathe
Sawhawgz, ruining the internet since 2012...
paragonbuilder
5:33 AM
Norwich, CT
Guessing to do it on a lathe youmake a jig to hold it then use a boring bar?
Yep.
Nc grease monkey
5:33 AM
Boone, nc
Now for domed pistons do you try to match the dome to what you're cutting or do you just do a flat cut?
