merc_man
merc_man
- 1:09 AM
- Feb 24, 2016
- southern ontario
I'd start cutting but am a bit accident prone. Thought I'd broken my knuckle in a Foredom incident last week.Finally got a hole cut in it. Now should i try and power wash it out now or just cut away?
I kinda of figured if i got a hole in it if ther was some flameabke still in tjer the pressure has some where to go.
They do stink, every time I weld on one to make a wood stove for the Amish I smell like I rolled around on a dead animal.You already cut it so what are you worried about?
Get it cut open and burn the stanky stench out
The stink is amazing. It just lingers with a person.They do stink, every time I weld on one to make a wood stove for the Amish I smell like I rolled around on a dead animal.
Opening is about 4 inch by 10ish. I do plan to make some sort of a baffle ther to help defect heat a bit.Looking pretty good!
How big is the opening between firebox and cook chamber?
You planning a vertical baffle, or open for airflow?
Is there a grease dam at the firebox?
Take the valve off an old tank and pour out the accumulated mercaptineThe stink is amazing. It just lingers with a person.
Havn't made a greese drip spot yet in it yet.
So it had no problem gettin to hot temps. I need to build a damper for stack still to hopefully help restrict a bit.It seem to flow the heat how you wanted? If it takes a huge fire to get the cook chamber heated, you may benefit from a larger opening there.
We had to do that to a friend's old country Pecos to get it to run right. Cut his wood consumption to about 1/3, and much easier to maintain even temps.
Definitely want a small dam for the grease at the cook chamber to firebox, grease running into the fire can get exciting. Even 1/2" or so at the low point should work.
Looks really niceGot it ready for a first test run sometime. Maybe this sunday.
ThanksLooks really nice
