brushwacker
- 9:53 AM
- Jan 18, 2017
- NW IN, USA
The other day at about 20 degrees after pumping the purge bulb about 6 or 7 times and normal choke procedure I pulled it about a dozen or more times with no pop, so I pumped the bulb 4 or 5 more, tried it them some more. After about 50 pulls i started up my truck and let the saw warm up about an half hour while I cut smallish wood with my old ms180 which started with an extra couple pulls or so which is usually 3 to 6. Both saws were left out in the toolbox in the truck overnight.
Found minimal info searching but the best i could gather, pump the purge 5 times, then choke it normal which is close to what I done but the next cold day I did just that and I believe it was 10 to 12 pulls before it hit. A bit much for a 67 year old man with an somewhat delicate shoulder. I bought this heated handle version so my hands wouldn't ache in cold weather. I have only started and used this saw about 15 tank fulls the few years I had it. Don't remember it starting off cold very well other years either.
So the goal here is will it start and how to start this 550 xp Mk 2 electronic in fewer pulls in 20ish degrees and lower temps without having to bring it inside to warm?
Also does it matter if the heat switch for the handle is on, weaker spark maybe?
