- 5:59 AM
- Nov 24, 2023
- Northern Idaho, Ehh
I wonder if the difference in operation plays a part, when you stomp on a 462 (mTronic or carb adjusted) it ramps up and when you let off it ramps down, almost like a sine wave (analog) where as when you stomp on the 500i, its almost instant full throttle, more like a digital square wave (on-off-on-off-on-off). Its possible that as opposed to say cutting a tree or firewood, where the 500i is running at more constant speeds for extended times (to get through the cut), when going through brush, its cutting through the small stuff faster than it can calculate its extended needs and ends up running the saw more lean over time and with the heat buildup and you end up with a roasted saw.While I agree with you guys about the abuse and also 50:1 mix what I'm wondering is why would a 462c and a 500i run side by side not have the same results? The 462's have been having their own issues but its what I would consider normal breakage. but like I said I've had 6 blown 500i's and 0 other blown powerheads. So what makes a 462 more durable in brushing operations than the 500i? This is what has me puzzled.
Do you get any information from hooking it up to the computer? I wonder if it shows information that would be helpful beyond starts/attempted starts. I wonder if there is any correlation of hours worked, hours ran vs idling. Not sure if they show any temperature deviations.
