cub cadet xt1LT42E E222 error code
eavinc
New OPE Member
5:34 PM
montreal
Hello. Sad to say i was six month outside my warranty. All this adventure started after hitting a root of my oak tree. the mower stopped. i powered it off, and it started to run normally. Finished my yard and the following week, mower would not start. I get a E222 error code, the mower can move around like a golf cart but i cannot cut my lawn. Brought my mower to a dealer and after 2 weeks and him saying he had spent hours diagnosting it, he told me that it was the left controller that was bad because no electricy was leaving it when you tried to start the mower. It was apparently a 1000$ repair. I contacted cub cadet, MTD for help and the left controller is retailed at 250$ and saw some used one's being sold for 150$ online. They told me that in their books, it would take the dealer less than an hour to do the swap. So i opened the the hood to see why i would be charged 700$+ for the repair. basically, it is 3 screws to undo the controller from mower and 4 connectors, 2 that come from the VCM and two others that got through a harness( big blue connector and smaller pine one) before heading to the mower motor. Since i wanted to make sure that this was the issue before i ordered the part because i had lost faith in this dealers honesty, i took out a multimeter. So i performed an ohm's test to the three pin connectors exiting the controllers that hook up to the motors, i get readings. For the right side, i get 20 on all combinations( i know the right side would be E3** but i wanted to compare readings), as for the left i get 20 for the top two and when i probe the lone pin (the one that does not has an empty slot at it's opposit, i get 23 for those 2 combinations. i do not know if this is still okay as the controller on the left side is smaller in size than the right controller and it goes through a wire harness before connecting to the left motor. The right controller exists directly to the right motor without going throug a harness
I put my mower back together and gave it a go and i could hear the left motor making an odd sound and it actually made the blade turn ever so slightly but error popped up again. i rince and repeated a few times with getting the motor to turn a bit but only if i unhooked everything.
So i am by no means an electronic/electric tech but i would sure appreciated for anyone's help. I've read on this site the cub cadet electronic chronicle and noticed some of you are very knowledgeable so if you can take a look at my situation, it would be awesome. i just don't want to replace this part if it's not faulty. i did flip the connectors between motors and still get the same E222 error. i downloaded the VCM module code and this error could be a faulty motor also as per my understanding. is there a way to test the motor? Thanks
Motorka
11:34 PM
EU
Returning long post....
Error code E222 on the Cub Cadet XT1 LT42E lawn tractor indicates a communication error between the mowing motor controller (Vehicle Control Unit - VCU) and the left blade motor .
Root cause analysis and logical flaws
The system detects interruptions in the CAN-bus signal or loss of engine status feedback. Common causes are:
  1. Poor contact at the connectors: Due to vibration or dirt.
  2. Damaged wiring: Pinched or split wires between the controller and the motor.
  3. Motor controller failure: Internal electronic error.
  4. Blade Blockage: Mechanical resistance that causes electrical overload and consequent communication blackout.
Diagnostic procedure and solutions
StepDescription of the procedurePurpose
1. Visual inspectionCheck if there are any foreign objects (branches, accumulated grass) stuck under the cutting area, blocking the left blade.Elimination of mechanical blockage.
2. Checking connectionsDisconnect and reconnect the connector on the left blade motor. Check the pins for corrosion.Ensuring physical signal continuity.
3. Wiring inspectionTrace the cable from the motor to the main control unit. Look for signs of rubbing against the chassis.Short circuit or open circuit exclusion.
4. "Power Cycle"Disconnect the security key, wait 5 minutes, and then reconnect it.Software reset (VCU).
Critical note
If a visual inspection of the wiring and cleaning of the connectors does not resolve the error, the problem is likely in the blade motor's onboard electronics or main controller . As this is a high voltage system (56V), unauthorized opening of components voids the warranty and poses a safety risk.
Suggestion: If the device is still under warranty, request diagnostics with a service tool that accurately displays the communication protocol parameters.
Does the error occur immediately when you turn on the mower or only when you try to start the blades?
eavinc
New OPE Member
5:34 PM
montreal
error occurs when i try to start up the blades. Out of warranty. i removed blades to make sure nothing obstructed the spinning motion. the deck is clean. Is there a way to test the left motor or the left controller? Unpinned all wiring and harness looks in great shape.
