Cub Cadet LT42E Troubleshooting, BUT NO ERROR CODES
lenabug
New OPE Member
1:46 PM
Georgia
3 years old, 71 hours
90% battery. Was mowing earlier just fine, I got off to move a huge toad that I disturbed, when I got back on, it would not go forward or reverse.
It does click when the key is inserted.
It does the double beep when on and engaged.
It even clicks when I push the forward or reverse pedal, but we go nowhere!
The mowing deck does engage when sitting, then cuts off after a few seconds.
There are NO error codes, which is really odd.
We removed the seat and checked the weight sensor contraption, when taken apart, a code is shown.
At a loss.
ALSO, HOW DO WE GET THE SUCKER IN NEUTRAL SO WE CAN PUSH IT BACK TO THE GARAGE FOR STORAGE!?!!?
Seachaser
1:46 PM
Georgia
I would try ALL connections. A little corrosion can go a long way. Then charge 100%.
Sloughfoot
10:46 AM
Norcal
Should be a lever on the back side to disengage the diff.
odonnse
12:46 PM
USA
At a loss.
Can you get the blades to engage?
tsungyupan
Active OPE Member
1:46 PM
Michigan
At a loss.
Have you solved the problem? Same problem as I am having. Four year old LT42E. The wheels don't move. I could hear a faint clicking sound near the rear axle when pushing the foot forward/reverse paddle. No error code. Battery fully charged. The blades run.
odonnse
12:46 PM
USA
This could be a drive motor controller or a drive motor issue.
