Cross Performance 254 top end
ZukiRyder440
Breaker of recoils
4:03 PM
NY
What was originally going to be a new piston only turned into needing a top end, heres the end result, the grooves in the cylinder started to transfer onto the piston after only 4 or 5 tanks. Dont mind those lowers...E11FC4C4-8594-4F11-BA18-5211B11E9906.jpeg5D6B2735-5ED9-4BAA-BE47-2FC4E501ACCE.jpeg
ZukiRyder440
Breaker of recoils
4:03 PM
NY
Got the new top end and piston in the mail today and I was actually kinda suprised at the quality. Not that its the best but I had my doubts. One of the lowers is kinda rounded on a couple of the corners but Im just gonna send it920DFC92-24EC-4A5A-A76A-59C072ED1268.jpegE040998E-D1B3-44E2-B9E5-0B43CC56C7B9.jpeg10596F63-B65A-448A-AC23-5CC3141B8098.jpeg323CDB8A-813C-4A3C-A640-C5E9A3DDB229.jpegF264499A-8530-4883-ADF6-8007B39CF563.jpeg
ZukiRyder440
Breaker of recoils
4:03 PM
NY
One thing i had noticed is that on the exhaust side of the upper was flatter than flat, I is gonna fix it. Itll be a while before i get more pics
ZukiRyder440
Breaker of recoils
4:03 PM
NY
Whats kinda interesting about this cylinder is that it has a decomp hole but not one on my OeM one693689DD-217F-4A29-89D1-BCF6B25185F9.jpeg
ZukiRyder440
Breaker of recoils
4:03 PM
NY
Piston looks REALLY good casting wise but there were some kinda shard edges that i sanded down the sharp spots a lil bit with 1500 grit, 2808133C-403F-47B2-B619-8D8598051E38.jpeg2808133C-403F-47B2-B619-8D8598051E38.jpeg
ZukiRyder440
Breaker of recoils
4:03 PM
NY
One other thing is that the intake on the Cross cylinder is a good amount wider than the OeM one.
4:03 PM
ZukiRyder440
Breaker of recoils
4:03 PM
NY
I got it all assembled and the first start was as you would expect, not very easy LOL. But I let it sit an idle for about 30 seconds the first time and about a 5 min break and went up to about 3 minutes. Not sure if there is a term for this method but I do it everytime I put a new piston/ top end on.
ZukiRyder440
Breaker of recoils
4:03 PM
NY
How wide are the skirts compared to oem? Almost look narrower but it could be a optical illusion…
To me it looks the cross piston is a touch narrower but I dont know by how much... dont know where muh calipers went.
ZukiRyder440
Breaker of recoils
4:03 PM
NY
Thats how wide the exhaust window was. Im not going to widen it when I go make port timing adjustments after the base and band cut.
Intake width is staying the same too.
4:03 PM
Stock ports looked tiny. How wide are they? 60%? It looks like you got a little fudge room there to widen them.
ZukiRyder440
Breaker of recoils
4:03 PM
NY
I dont remember.. ill has to measure tomorrow and they were very small but these things were factory hotrods
ZukiRyder440
Breaker of recoils
4:03 PM
NY
The oem ones were anyways, havent gotten this one into wood yet.
