ZukiRyder400
Breaker of recoils
- 8:02 PM
- Apr 11, 2018
- Your bum
How wide are the skirts compared to oem? Almost look narrower but it could be a optical illusion…Piston looks REALLY good casting wise but there were some kinda shard edges that i sanded down the sharp spots a lil bit with 1500 grit, View attachment 305459View attachment 305459
To me it looks the cross piston is a touch narrower but I dont know by how much... dont know where muh calipers went.How wide are the skirts compared to oem? Almost look narrower but it could be a optical illusion…
Stock ports looked tiny. How wide are they? 60%? It looks like you got a little fudge room there to widen them.Thats how wide the exhaust window was. Im not going to widen it when I go make port timing adjustments after the base and band cut.
Intake width is staying the same too.
I dont remember.. ill has to measure tomorrow and they were very small but these things were factory hotrodsStock ports looked tiny. How wide are they? 60%? It looks like you got a little fudge room there to widen them.
