- 7:29 PM
- Dec 3, 2015
- Banner Springs Tennessee
MS390 in the mail Monday.I'm sending my 450 rancher
Shoot…I’m gonna need a bigger garbage can.MS390 in the mail Monday.
Finally had a chance to get back to this Mac cylinder. I cut the pockets 0.032” deeper to match the amount I removed from the cylinder base. Then I swapped out the boring bar for a groove cutting tool. I then re-cut the retaining ring groove for the flywheel side bearing.View attachment 376647View attachment 376648
Hopefully all the fuss is worth it. It has been a learning process for sure.I love it.
Going to be a bit before I get after 'em, I will update here when I do.View attachment 380629
Here is what the finished product looks like. If you look closely, you can see several pocket voids in the casting that showed up after doing the base cut. Both cylinders I did were like this…I thought it was noteworthy as I haven’t seen that on any other cylinder I have cut. Anyway, these are now with @Stump Shot for the port work.
How long did that take?For mine, I welded the used bearings solid onto a shaft. Then I simply dipped the bearing in toothpaste and re ground the pocket using a string bow from my boy scout fire starting kit.
Outta curiosity, would a bigger jug (like one off a SP81) be viable for this sorta treatment?View attachment 380629
Ya know, I don’t know for sure, but I think it might.Outta curiosity, would a bigger jug (like one of a SP81) be viable for this sorta treatment?
I have never done a 2-piece head, so I can't say. I'm not sure there would be a good way to hold a removeable head down on a mac jug. As it is, there isn't much extra meat on the bearing pockets, so I am pretty much limited to getting the squish set to a respectable value.Wouldn’t a 2 piece head be easier?
Not feasible, the exterior frame bolts right to the top of the cylinder head, so there isn't any extra room to speak of, that and you can't just use long bolts as it doesn't go together that way.Wouldn’t a 2 piece head be easier?
I was thinking studs. There is room on the bottom flange for that. Inside the clamshell clamping bolt perimeter.Not feasible, the exterior frame bolts right to the top of the cylinder head, so there isn't any extra room to speak of, that and you can't just use long bolts as it doesn't go together that way.
Possibly if one could get them recessed in the head. corners of the cooling fins would have to go. then the whole thing be the same length and a couple of 1/4"-20 threads tapped into the top of the head on either side of the sparky hole to mount it up to the chassis, as well as it not be too big around to fit inside, might be square would be easier to work with.I was thinking studs. There is room on the bottom flange for that. Inside the clamshell clamping bolt perimeter.
