Confusion on rings for 361
kielbasa
2:37 PM
Kewaskum, Wi
Hi guys, I attempted to order rings for my 361 from the local Stihl dealer - apparently a minimum of 4 week backorder.
So now I'm contemplating aftermarket Caber rings, however I'm reading that some folks like the Cabers, others mention that the Cabers are hard and not recommended....or am I just overthinking this?
Thanks for any input!
PA Dan
3:37 PM
White Oak PA
@Definitive Dave
3:37 PM
I've only used 60+ sets of cabers
Rebuilding saws
So I'm no expert
But I've never had a saw come back
Same with oem rings of course.
smokey7
3:37 PM
Detroit
I dont like the f cast rings as well as the std ones.
kielbasa
2:37 PM
Kewaskum, Wi
any specific reason you don't like them? this is what scares me.....do they tear the bore up or something?
I looked at several places to order the rings from, i have not seen any option of ordering standard vs fcast -where do you guys get the "standards" from?
kielbasa
2:37 PM
Kewaskum, Wi
Rebuilding saws
So I'm no expert
your thoughts on the fcast vs standard?
PA Dan
3:37 PM
White Oak PA
Fcast are harder and more brittle. They take longer to seat too. Not sure where they would be an advantage? Just my 2 cents.
3:37 PM
I'm assuming the fcast would be tough on aftermarket cylinder plating
PA Dan
3:37 PM
White Oak PA
I have an email into Caber asking pros/cons of fcast, and in what instances one should or should not use them....since they offer a choice I certainly would like to know when and where to use which!
Good idea please post it if you get an answer.
jacob j.
Only the weird
12:37 PM
Coastal Oregon
Good idea please post it you get an answer.
I'd like to see this too - I've used probably over 200 Meteor piston kits and maybe 40 sets of their rings (no F-cast though, that I'm aware of).
3:37 PM
I've bought meteor piston kits and caber rings from the Greek on eBay
Northwood saw,hl supply.amazon
And Bailey's
And have never seen an fcast
Must be special order.
PA Dan
3:37 PM
White Oak PA
I did buy at least 1 set of F cast rings. Can't say how they ran since I broke the first one going on the piston. The second is probably still on the bench somewhere.
