Cleaning up nasty neglected saw?
Flint Mitch
8:44 PM
Michigan
Can anyone enlighten me on what the part # is for whatever goes in that hole. Im not seeing anything on the IPL but I'm not the brightest crayon in the box sometimes. Thanks!
Sent from my SM-G981U using Tapatalk
Lightning Performance
8:44 PM
East of Philly
A beat up screw. It aligns the bar slot.
Need a pic?
8:44 PM
East of Philly
Notice the hammer marks from the bar slot beating on the loose screw.
20201201_121707.jpg 20201201_121644.jpg 20201201_121610.jpg 20201201_121605.jpg 20201201_121557.jpg
The first pic is a tight one as it was. The second to last pic is one that was good and snugged up. The others were loose but usable
Flint Mitch
8:44 PM
Michigan
davidwyby
Rural desert logging
5:44 PM
Extreme Southeast CA
****don’t get the coil, etc. wet...if you do,
Might be able to dry it out in the oven.
8:44 PM
East of Philly
I wash coils with water all the time if they are greasy. Use hot water and no detergent. Blow dry and your good. Most stuff gets a sauna next to the wood stove or out in the sun on a black plastic bed liner other times. Good way to check a cracked coil is to wet it.
Most people use carb cleaner or brake clean on them. Not really a good idea imo. That strips the parts protection off and they rust when sitting.
davidwyby
5:44 PM
I got a 2pc ign for a 266 wet and had to dry in oven. Then it quit again after a few weeks. Haven’t messed with it. It is quite old, so...
