Clamp for Intake Boot on 350 Husky
Cut4fun
Redneck Chainsaw Repair
5:13 AM
Ohio
I've used the oem replacement, husky 372 and poulan 2800-380 3750 clamps. Gives you a whole bunch to choose from there just in poulans.
OEM one is like $2
old guy
Love me some Husqvarna
4:13 AM
Becker Minnesota
I have been using the 372 clamp, but I have to cut away more of the plastic than I like, this is probably not serious, don't know if the 390 clamp is bigger. OEM 372s are $5 each at my dealer.
Tor R
Novice, Leg model #2
11:13 AM
Mandal
Onan18
OPE Sponsor
5:13 AM
Georgia
Joe, what comes in the kit ?
Is it a new boot as well as a proper clamp ?
A new boot would be worth $12
Tor beat me to it, it comes with a partition wall (the plastic part) and the new clamp. The boot is reused and sold as a separate item. I don't think that I have EVER seen a bad boot on this series.
Joe
angelo c
Coal Member
5:13 AM
Partition set has # 537 25 13 02
https://www.partstree.com/parts/husqvarna/parts/537251302/
Separeted parts is # 537 42 28 01 and # 537 43 88 01:
https://www.partstree.com/parts/husqvarna/parts/537422801/
https://www.partstree.com/parts/husqvarna/parts/537438801/
I've never bought the 390 clamp, but if it's perfect match I rather prefer that one compared to the 346 clamp
https://www.partstree.com/parts/husqvarna/parts/505283302/
Well done Tor,
Thanks. I've got one to do on a 350 and the existing clamp-boot thing system is a little confusing for a Stihl guy.
94BULLITT
5:13 AM
VA
Napa part number
686-5883
I've been using these, I think a box of 10 costed me around $20 or less
Are sure that is the p/n. I can't get it to work at Napa, or maybe I need the line code.
94BULLITT
5:13 AM
VA
when JRed came with their service bulletin for trimming the plastic clamp and use one metal clamp it was the clamp from 390 they recommended.
If I got it correct it's the same screw clamp JRed used on 2077/2083, later 2186 and 2188
By trimming the plastic clamp do you mean cut it all the way off? That is what I did.
Genius
First member of ASlite to receive a infraction
5:13 AM
Uncle Willys basement
If I delete the "-" out of the p/n it comes up as a 7'' long cv joint boot clamp.
Hmm, I'm not really sure... That's the PN that worked for me.
@Termitebuffet , he's the one who steered me onto these clamps and took that picture for me. Maybe there is a new number now that supersedes that one.
5:13 AM
When I Googled the 5833 # it comes up as the small end cv joint strap. That would be close. A 7" strap is probably about right. Circumference of a 2" circle is 6.28".
94BULLITT
5:13 AM
VA
It is not cut. That is the plastic part has a gap around the rubber boot making it look cut.
