China 660 clone. Anyone else have a tank leak?
Stevetheboatguy
5:41 AM
Nw IL
The tank on my clone weeps/leaks on the rear seam. It's not a horrible leak, but there nonetheless.
Any ideas to seal it up without uglying it up?
Pic of the seam that is giving me trouble.
Steven
6:41 AM
I imagine that would make the saw fail a pressure test. If it is new, I would ask for a replacement.
If not, I'm not sure if Loctite 529 would work on that or not, but that is what I would try.
The caps always seem to leak, but are easily fixed with a 55 cent O ring gasket from an auto parts store.
paragonbuilder
6:41 AM
Norwich, CT
How does a fuel tank factor into a pressure/vac test?
smokey7
6:41 AM
Detroit
I dont believe any sealant would "look" good. For the price id just get another tank. But if is a new purchased tank id be asking the seller for a replacement. You shouldn't have any trouble getting a defective tank replaced since you are not citing a problem with how it looks you have a problem with it working as it should. I mean i doubt the seller had to modify or mess with your money you paid before spending it so the same should apply to your parts purchased.
Stevetheboatguy
5:41 AM
Nw IL
It's a new saw. I ordered it from hl on one of their after Christmas sales.
The reason I'm trying to fix the leak is. Tanks are on backorder. They don't have a replacement to send me right now.
So I figured if I could get this one sealed up without making it ugly. I wouldn't worry about getting a replacement.
It's not a huge rush on getting it done, but I do have some larger wood that I would like to see how it preformed compared to a oem saw. And I'd rather not get fuel leaked on me or have it split all together. Know what I mean?
Steven
6:41 AM
Yes, but not always on the first time. The O rings from the auto store work a lot better than those flat washers that stretch way too much when you tighten them.
6:41 AM
The new China ones sometimes have the lever set wrong, and it leaks (results in a saw with hydro lock, very hard to start).
