thomas1
┌∩┐(◣_◢)┌∩┐
- 5:25 AM
- Dec 29, 2015
- Cristobal Colon
Who knows hydraulic stuff?
Olyman
I know some, what's going on Randy man?
Sounds stupid but if it has a detent/check valve and the valve is older it could be stuck. Or its plumbed incorrectly
YEP! OR SWITCH LINES AROUND ON THE VALVE BODY.I'm thinking that I've plumbed into the wrong port.
New valve. Impossible to plump wrong.
Pressure may be too high for it.
Variable speed so you can take the right amount off the base each time?
I know both of you and I agree! As scary as it sounds!Bro?
Is it hooked to hydrostatic system? A standard 3500 psi or whatever valve won't like 20,000 psi... it's like special valves and cylinders on the John Deere garden tractors... built for that pressure, whereas a log splitter valve might not like it.
Be careful with that hydro stuff... pinpoint leaks (shooting a straight stream) will cut your finger off. And if the valve decides to burst due to too much pressure, well that is like a grenade.
Just an old JD 1120 tractor.
I've got something figured out.
Got the bail money?I know both of you and I agree! As scary as it sounds!
No...he needed something bigger.Did you use one of your legs to clear debris out of the line, or valve body?
So his penis won't work either. ...No...he needed something bigger.
A collection will be started when necessary! Notice I didn't say if!Got the bail money?
LmaoA collection will be started when necessary! Notice I didn't say if?
I take that offensively.Your welds look a little funky. I hear there's a guy in MO that can weld like a mofo...![]()
