Chainsaw Porting Theory
czar800
10:39 PM
Ellwood City
This is the cover on my 024 it only has the pipe with stock front opening and it seems to run right with the 026?
tickbitintn
9:39 PM
middle tn
I have a 359 with the cat muffler I opened up the baffle and put an opening in the front with just a screen over it..... It's loud and I think is leaving some gains on the table.
Sent from my XT1254 using Tapatalk
David Young
Safety First !!!!!!
10:39 PM
vt
I think the side opening help muffle the sound. very few saw manufacturers go out the front.
the closest is the jungle style muffler from husky or dual port from stihl but even that is turned 90 degrees.
The ol boys down south with the muffler race saws go right out the front of the muffler.
I think the pipe is the way to go but no proof......Yet
David Young
Safety First !!!!!!
10:39 PM
vt
jmssaws
Banneded
9:39 PM
I've tested it many times fellas, the bigger the better and on the side.
Close your side port and put the same size hole in the front cover and you will feel it loose.
2" long 1 1/2" pipe on the side were the factory outlet is on a big stihl makes the most power on my saws. I have tested this many many times.
czar800
10:39 PM
Ellwood City
put a blank steel plate over the front hole. test it. then use a unibit step drill and increase the size testing on each 1/8" or 1/4" step
Next time I run both saws going to be swapping covers. I've thought about cutting a piece of metal and sliding it in and out like a stock muffler screen slides in.
MG2186
9:39 PM
Summer,IA
Dam now I'm going to have make all new mufflers for saws, I got 2 pipes coming out front at angles on all of them
XP_Slinger
They’re Just Saws
10:39 PM
Central NY
Good stuff! Side outlet maintaining sound characteristics makes perfect sense! Guess I'm lucky all my saws got an additional side port instead of a port in the front. I did the mods this way because it made more sense function wise as far as burning wood and keeping the heat off my hands.
jmssaws
Banneded
9:39 PM
A oem dual port cover will set a dead tree on fire.
9:39 PM
Now........don't be too hasty.
Point........counterpoint is the way to learn.
David nailed it, but no one was listening.
The ol boys down south with the muffler race saws go right out of the muffler.
Wanna make it scream........straight out the front, but below the exhaust port works.
For a strong work saw.........out the side seems to make the most power at a lower RPM.
10:39 PM
Gotta be some wave reflection.
I'm seriously thinking cone funnel out into larger cone funnel in.
jmssaws
Banneded
9:39 PM
I don't know anything about a race saw but a work saw it works best out the side.
I took the front cover off a 660 and the Only thing it changed was noise,stock saw though,never tried with a ported one
