Stihlbro
- 11:21 PM
- Dec 29, 2015
- Virginia
Absolutely, unless you are cutting at high elevations. Compression increase is a power adder. Too much compression can work against you in a work saw. Work saw I'm classifying a saw saw that runs all day. Not the one truck load firewood cutters. Not your 3 minute YouTube videos.
I'm not saying it's not done, or I am right. I am speaking of my experiences from my uses. The closer I get to 200lbs of cranking compression the more I find tunes change with saw getting to operating temperature. Cold saw it so rich it won't rev up till it gets to temperature.
Saw with closer to 175/185 seem to perform better from start to finish. Make sense?
Stock saws once tuned in, have you ever had to retune once dialed in in same cutting conditions?
