Terry Syd
- 6:02 AM
- Jan 18, 2016
- Comboyne, NSW Australia
I spent some time with Jerry Branch on the flowbench at Flowmetrics. The guy was a true artist - and genius. I remember him showing me a stock head off a V8 and then his 'ported' version. The stock head had almost a straight open runner to the valve pocket - the same runner on the 'ported' head was considerably restricted and no longer straight. Hell, I would have ground out all the material he had put in. - However, the flow bench doesn't lie, it just records the reality.
He did a funny demonstration with a very slick looking air horn that was an accessory for a motorcycle carburetor. He put the air horn on the bench and fired it up. I forget the exact numbers, but say it was flowing 600 cfm. He then took a small piece of clay (he used a lot of clay in his work), rolled it up into a ball about the size of a pea. He stuck the 'pea' on the edge of the air horn and the flow meter jumped up to 625 cfm. He then added another 'pea', up again it went to 650 cfm - he ended up with six of these 'peas' on the edge of the air horn and flow meter was showing close to 750 cfm.
I said, "it looks like the air horn may actually restrict the flow". He replied, "no, the carburetor it mounts on only flows 450 cfm". I then said, "so the air horn is completely useless". He laughed, "nope, it makes the owner FEEL BETTER about their bike". - (some porting jobs could fit that description)
As far as the carb question, yeah I think guys should spend more time trying to get the two circuits dialed in a bit better. There is a lot of extra torque and resistance to bogging that can be achieved by getting the fuel mixture closer to the optimum throughout the RPM range. Most people concentrate on the 'top end', up where the horsepower is, but that is only part of the powerband that a WORK saw utilizes. After dialing in the carb, the saw may not make anymore horsepower, but it will have more 'grunt' for when you need it.
As far a 'bigger' carbs, I wonder how many air filters are the real bottleneck in the intake. I expect it would be very informative to have access to a flowbench to run carbs and their airfilters. Although we don't have access to a flowbench, we can check the RPM with the filter on and with it off. I wonder how many guys do that before they start trying to cram a bigger carb on the saw...
