Chain talk
jmssaws
Banneded
9:18 AM
It takes mucho ponys to run it.
The chain on the 7900 is 3/8 but pretty good too,9pin on it
CR500
10:18 AM
Western NY
Don't put .404 in the7900... I want to see it do good within it's limits lol
CR888
12:18 AM
Australia
One hard to over come issue with .404 is its hard to reduce chain speed & increase torque with a sprocket swap. A 7 pin .404 sprocket is bigger than an 8 pin 3/8. The old saws that had much lower max rpm and put down their power at much lower speeds overcome this but today's high revving saws make .404 a bit challenging in oz hardwood. I run a lot of it but would love the option of say a 5 or 6 pin sprocket to slow things down and put some torque behind the cutters.
jmssaws
Banneded
9:18 AM
Mutt runs a 9..
Hell, I'd run a 10 if the freaking chain would stay on the bar... Lol
The 7900 has a 9pin on it but it wouldn't like the 404 that's on the 066,it's stronger than the dolmar by a good bit and it's pulling it hard.
The 50" 404 with full comp and a stock chain don't pull as hard as that 20" 404.
mdavlee
Hillbilly grinder
10:18 AM
TN
Mutt is a 7900 Matt has that mike built,it's quite stout. Best running one I've ran.
I think John Reilly has a couple that are stronger. The Solo isn't quite up to it and has the longer stroke advantage.
mdavlee
Hillbilly grinder
10:18 AM
TN
John's 681's are bad dudes..
But I'd like another crack at em with the mutt set up the way it is right now.
I'm sure it would be close. I would like to see a couple of his against that one with the same chain/operator. I'd like to know how close it is without a head and big carb.
jmssaws
Banneded
9:18 AM
He's gonna send me one to play with but I only have stihls to compare,I'll have to send it to you or Matt to see how it does.
mdavlee
Hillbilly grinder
10:18 AM
TN
Maybe we can get him to come up for the GTG in December.
