Woodtroll
- 2:08 PM
- Oct 7, 2024
- Mtns of SW VA
The crank did not get bent and then unbend itself and then bent again. So don't worry about that.
And the crank is not changing position while you're advancing the chain by hand. The clutch drum should be spinning freely while the crank stays stationary. I don't believe the crank is bent, either, but I'm definitely curious to see what you figure out.
