- 7:43 AM
- Mar 13, 2023
- Maryland, USA
I want to open it up more. Needs another hole.What does your muffler look like?
It doesn’t seem to me like it’s there either. Is that saw still running the same cylinder that you took a huge squish cut from?
@farminkarman , thanks for the recipe. It's not there yet though. It needs more fuel. Smells lean. Once the rings fully seat I think it'll be hungrier. Thoughts?
@Ketchup , @drf256 , @Canadian farm boy ,@huskihl , @Mastermind , you've all done a bunch of these. What do you hear and see? Input always appreciated! Don't be nice!
106, 124/127, 78
Indeed it is.It doesn’t seem to me like it’s there either. Is that saw still running the same cylinder that you took a huge squish cut from?
I've been obsessing over the lowers.I’m afraid I don’t have a lot of experience with 362. I’ve done three. The last one was a V2 and was the strongest. 105 (max width)/125 (flat)/76, dual port exhaust, 1/3 off the key. I took a significant amount of flange away from the lowers. If it’s blowing 235psi, I would raise or widen the exhaust.
Jred Sounds great! I'll have a hard time taking the bosses saw hostage for another weekend of grinding. I definitely need to give it more fuel for safeties sake. I'm with you. It's still struggling. Still better than stock. but not there.I lost a bunch of saw testing videos from my phone about two months ago, so I only have what I posted on YouTube. If my memory serves me correctly, the last 362 I did ended up being within a half second of a Jred 2165 I sold. The cuts were in the same log, but different bar & chain. Here is the Jred for reference:
Gotta be careful messing with the cylinder extensions…you don’t want to cause the strato ports on the piston to short-circuit to the crankcase.I can’t totally see what you did, but it looks like you ground a scoop into the flange at each lower. I did a bit of that with what was left but I completely removed more than half the flange in front of each tunnel. I was tempted to raise it past base height. I might next time.
I have also found generally that a little extra work in the back of the upper to make sure all the transitions are smooth goes a long way. 261/362 can be hard to see in that bend. I kinda grind by feel in there.
That saw doesn’t sound like it’s hitting the limiter or a high note. Needs more RPM?
What was bothering me about the lowers is that they are visibly equal to or less than the area the uppers have become. That being said I rolled with it as is for two reason's. One, the piston seems so asymmetrical, and the skirts travel so low into the case, I feared weakening the bore flange sleeve thingy by making it too thin. Two, the jug is so low now that at bdc the piston crown is only unblocking half the uppers.I can’t totally see what you did, but it looks like you ground a scoop into the flange at each lower. I did a bit of that with what was left but I completely removed more than half the flange in front of each tunnel. I was tempted to raise it past base height. I might next time.
