Carb not holding pressure
merc_man
merc_man
3:11 PM
southern ontario
Got a saw that seems to get the spark plug quite wet. I cant get the saw to even pop its so wet.
Put the mity vac on it and wont hold presure. ( digured it wouldnt).
Figire its the needle valve. Dont have the propper tool to check it and it looks like it mwter lever sits down below the base of carb.
Should i just tweak the meter lever a bit and recheck to see if it will hold pressure.
I just put a carb kit in. (Just gaskets.)
merc_man
merc_man
3:11 PM
southern ontario
It looked good and clean.
You know what the setting should be.
Cant recall the carb but its a husky 181.
merc_man
merc_man
3:11 PM
southern ontario
Its a tillotson carb. Cant recal the numbers
Simondo
8:11 PM
UK
Hook button or just button on the metering Diaphragm ?
Chainsaw Jim
Con Artist LLC
12:11 PM
Springfield Oregon
So you literally mean gaskets and not diaphragms? If the metering diaphragm is slightly stiff it will cause this problem. A weakened or wrong metering spring will also do it.
Here's a pic of the proper setting. The lever is flush with the bottom of the pan. 20170425_124759.jpg
BuckthornBonnie
3:11 PM
Penn Yan, NY
Here's a pic of the proper setting. The lever is flush with the bottom of the pan. View attachment 67188
Yep, stiff diaphragm could be culprit if you didn't replace. Assuming gaskets/diaphragms are in the right order, then make sure there's no gunk as mentioned above.
Spark seem ok?
merc_man
merc_man
3:11 PM
southern ontario
Yes the diaphram too.
Chainsaw Jim
Con Artist LLC
12:11 PM
Springfield Oregon
There should be a little play on the lever before it lifts the pin, so it shouldn't lift it at all when the lever is barely pressed.
Little chunks of the sealer they use around the edge of the welch plug will come loose after cleaning with carb cleaner. Use a sewing needle to clean it out if it's there.
merc_man
merc_man
3:11 PM
southern ontario
Playing with the carb this am. Recleaned needle and seat area and rechecked. It leaks a little but really slow.
Whats your thoughts. Ok or look for another needle.
merc_man
merc_man
3:11 PM
southern ontario
Well i just found my problem.
Not the carb. Rechecked spark and nothing. Wiggled wire and spark.
3:11 PM
It should not leak. A leaking carb will allow the saw to fill the crank case with fuel, and then the saw will not start (will feel like a ton of compression). Unless you empty the tank each time, and don't transport it with fuel in it, I would fix the problem. It is a problem I would not want to deal with (often transport full saws on the ATV, etc).
Replacement carbs are very cheap and usually work.
merc_man
merc_man
3:11 PM
southern ontario
I found a used carb. May pit tje needle from it to this one or try that one first.
Other problem is this isnt my saw and guy dont wanna pit any more money into it. Cant get the new ignition part anymore and cost with shipping on ebay is nuts for a new one.
3:11 PM
If the owner does not want to put any money into it, than stop working on it, it is not worth it.
merc_man
merc_man
3:11 PM
southern ontario
I know but now its mine lol.
And i wanna get it going. I might just leave it for now and see if i can find a parts one mabe.
To me this saw is worth $150 ebay part to get it running.
