Adirondackstihl
- 3:02 PM
- Dec 4, 2015
- Upstate NY
There's always bacon my friend......
That turtle cake is incredible. How does gluten free cake taste? Much different than regular cake?I remember someone saying they liked turtles -this one was a gluten free special order birthday cake my SIL made awhile back.
The metering spring pre-load, rate and size of the metering orifice are all elements of the idle and ramping in of the low speed circuit. If you start shimming up the metering spring, the idle will get a bit leaner and the ramp is slightly more delayed - in other words you change the tune of the carb. I'm thinking that working with the 'pulse chamber' may be the best way to approach the problem.
It is going to be a long time before I wear out another diaphragm, Hell I haven't cut wood in two months and probably won't be for another two months (medical operation and recuperation). I've wanted to see if the metering spring between the lid and the diaphragm in the pulse chamber would smooth out the idle, perhaps someone with a carb that is giving an erratic idle could try it.
In order to center the metering spring over the center of the diaphragm, you could drill a small indent inside the lid that the metering spring would sit in. Then holding the carb upside down, you move the lid 'up' into position so the metering spring stays in position. I don't know if the mod will work, and if it actually does, what kind of spring pre-load would be required - that's something a modder will have to work out.
If the mod did work to create a more consistent idle, I expect a lot of guys would like to know about it.
Amen to that.ght not agree on porting......but when it comes to carbs.......well, he's
Me too,after I port one I'll go through a large bucket of carbs looking for the right one. I'm out of control looking for the perfect tune.I'm picky as hell about tune
I tune every saw I see someone using whether I know them or not.
I can't listen to a fat saw
I was wondering the same thing. Main nozzles/check valves are only about $6 each to order them and easy enough to check and replace if needed.I'm wondering if the check valve in the main discharge nozzle may not be seating correctly. At an idle there isn't enough low pressure at the venturi to draw fuel. Under those conditions, the nozzle then provides a passage for air into the wet side of the carb. What happens is that instead of pulling the metering diaphragm down, it is easier to suck air through the nozzle - thus we need the check valve in the nozzle for idling.
Maybe after a while idling the check valve shifts around and seals again and the result is a variable mixture ratio at idle. If you have a good carb, you could try swapping the discharge nozzles and see if that fixes the problem.
I was referring to the picture shown where the "snorkel" is offset on the clone. If you've ever installed the filter base on the 066/660 you'll know it isn't adjustable and forcing it to fit is a hamfistable offence. LolThere's no need to swap the plates, everything lines up just fine
A very strong saw can be made a turd in a second with a screwdriver.I've been all over the place on the tune debate. At one time I was all about keeping them as fat as you could to make them live longer. Then........I started leaning them out a little more, and a little more. Now I'm sorta in the middle. They can't be too lean, or they run so hot that they die too soon, but they can't be too fat, or they never perform like they should. I've said it before, and I'll say it again........tune is everything.
Beat me to it LOLDamn. I thought it was the chain.
Yours was one of the ones that wouldn't lean the h far enough right?
