- 4:23 AM
- Dec 31, 2015
- East Jordan, MI
The bolt/cylinder thread discrepancies are known problems on these. Some are fine, some are coarse self threading...
I'm feeling under the weather today, so progressing very slowly, but I did put the piston in the cylinder, put Dirko on all the surfaces, and bolted the engine into the chassis.
I will tell you that next time I use an AM cylinder, I will make sure the threads are clean before I put sealer on the engine. Ended up putting locktite on just for lubrication, an working the bolts back & forth until they punched through the case.
Need to take a break, but will continue cleaning & assembly later.
Your suppose to fire up her oven before she goes to bedMaybe tonight I'll fire up the oven when the wife goes to bed![]()
A slight transfer lift yields a better blow-down number. More RPM at the expense of grunt. The best gains IMO were widening and dropping the intake at the opening point (time/area) and an ignition timing bump. Everything else was a waste IMO and they just suck down fuel. Have not tried a popup yet. That could be a "Shaky Pete" with the 49mm jug. My favorite was the 310 with a lightened piston. It ran very well against the others and had far less heat to deal with than a 390. I would not do much with the timing on an 039. Checked some notes. The early 029 jug had the best stock timing numbers but, they are not consistent enough to give numbers on.Has anyone ever tried to play with the upper portion of those transfers??? The boxy look of them just seems like it does not facilitate a smooth flow of the mix.
My very first experience with one was the same way. A person can easily get caught up in it and go into a rage during the last few turns when they start thinking of the hamfist that wasted an entire bottle of loctite on one nut. LolThe 1st one I ever done needed vice grips right to the end.
These Clamshell saws are just different!
About swapping the 044 carb- the one on your 029/039 is probably bigger. Mine both wereWell ... It's ALIVE!!!!
I thought I did all the hard stuff yesterday, but that is only because I'd never put one of these little B******* together before!
I thought I had figured out a good method of drilling a hole in the top cover for the decomp valve, but when the saw started spinning like a helicopter I realized things had not gone as planned. Gorilla Glue is helping me fix the top cover, and I finished shaping the hole with a razor knife.
And when I broke the metal end off of the kill switch wire, I had to break out the soldering stuff, but it is fixed!
The replacement bar bolts I ordered came today, but of course they are the wrong ones, so I will not be putting it in wood any time soon.
Also, the idle was very erratic at first, seemed to settle down some after some run time and adjusting. I think the carb may have sat for a long time and needs to be used a bit. Hopefully it will clean up on it's own. The saw did tach up nicely, run clean, and was 4 stroking, so that was all encouraging.
I considered putting the spare Huztl/Farmertech carb I have for the 044s on it, but when I pulled it out and looked at it, I was very disappointed. The first one I got through them said ZAMA on it, and worked very well. This one is a no name, has a lot of machine marks on the outside, the adjustment screws are very stiff, and idle screw is as big as a horse! That said, it looks like an 044 carb would go right on one of these things.
Since the carb on it is a Walbro, I'll leave it on and rebuild it if I need to.
Now if I can only get my replacement parts to come, still need a tank vent and the long bar bolt (they sent me the short ones).
I'm anxious to know how this thing will cut wood. It was an inexpensive project, but a heck of a lot of time, and a real learning curve. These Clamshell saws are just different!
