- 1:59 AM
- Dec 24, 2015
- Coastal Oregon
Looks and sounds great Tony - I can hear from you pulling it over that it has some monster compression.
I’ve found mine to be happy in the 14,200 range also. Maybe a little less with a 36”For the record.... first full no load run with the tach went a tad lean and pulled low 15's
2nd run was 4 stroking nice and was at 14700
Settled with it on 14200 4 stroking strong for its first tank
You dont need big wood if you noodle.First cuts today
Didn’t have big timber but these logs are an Australian class 1 hardwood rated for inground use and really hard.
The saw has bulk grunt but it’s owner will need to run it in some big timber when it gets home.
the saw is staying with me for anothe week and I should be able to go find some bigger timber next weekend.You dont need big wood if you noodle.![]()
