- 8:17 AM
- Dec 31, 2015
- East Jordan, MI
359...closed or open port? If open, is it plastic with the aluminum riser? More cc that 357? Just wondering about the differences
heres a 353 but same ideer
The transfer dividers on the 353/359 must be cast into the transfer covers?
My 357xp has the base cut and a popup, plus port work... and it has no problem pulling a 24" bar. I guess you could call that torque.I have a 359 that Randy cut the base and squish and I ported, the thing is a torque monster, I also have a 357 that I did a gasket delete and ported, both are good runners. I prefer the cut base and squish, I'm a torque kind of guy.
Clint, that would look GREAT in my barn... Just sayin!My 357xp has the base cut and a popup, plus port work... and it has no problem pulling a 24" bar. I guess you could call that torque.
If using a 359 cylinder, I say no stuffers.I ported a 359 cylinder and cut the base and squish so I can see how it stacks up against the 357 with a base gasket delete and a large amount of widening and massaging.
The no stuffers thing came from someone I trust so I am curious to see if more builders pop in here with their opinion on that.
