br-350 hard to pull rope
mikeyb
Active OPE Member
1:59 AM
ohio
originally came to me locked up, found flywheel sheared due to backed out coil screw. replaced coil and flywheel. now can't pull to start, feels like excessive comp when assembled. removed plug, pulls fine, removed muffler and reinstalled plug can't pull. removed carb can't pull, remove plug pulls correctly. Direct port. what am i missing? piston and bore look great like low hour machine.
hacskaroly
2100 Fanclub Member
11:59 PM
Northern Idaho, Ehh
Have you rotated the crankshaft to different positions (TDC, BDC...etc) and reinstalled the plug and see if it rotates at all, or does it do this in all positions?
mikeyb
Active OPE Member
1:59 AM
ohio
seems to be at tdc .even installed shorter plug to make sure wasn't hitting. just had a thought , scary but could the hard stop have egg shaped the rod enough to cause the bind ? it does pull just hard at each tdc pass .
hacskaroly
2100 Fanclub Member
11:59 PM
Northern Idaho, Ehh
Just so I understand, it pulls hard at TDC with the plug out? Have you sprayed some WD-40 or put any 2-stroke oil in the cylinder to ensure the piston is moving freely (no sticky spots)? Not sure if that will play a difference. I try to make sure the piston has plenty of lube when troubleshooting and it isn't running.
redneckhillbilly
12:59 AM
NW MT
when the flywheel sheered, could it by chance have damaged any of the starter pawls or is the recoil possibly binding up?
mikeyb
Active OPE Member
1:59 AM
ohio
pulling fine and dandy with plug removed . not rubing recoil and pawls are good, thinking now rod related to hard stop, was hoping to avoid total disassembly.it is helpful just talking out these questions.
EFSM
1:59 AM
Extreme southern IL
I’ve never seen a forged rod bend. I have seen Stihl’s stamped rods bend and cause strange cranking issues. You’re sure nothing is jammed in the squish band area? I guess coil and flywheel are OEM parts?
mikeyb
Active OPE Member
1:59 AM
ohio
yes, oem parts, bore scope didn't see anything and doesn't bind without plug installed. probably tear down after hitting the lake today. weirdly 62 deg today in Cincinnati, maybe catch dinner lol. appreciate the input.
Stihlcutting
OPE Member
1:59 AM
I know that I am way late to this thread. Have you turned the engine upside down with the spark plug out and pulled the starter to see if there is raw fuel in the bottom end. It has gotten me a few times.
