Marshy
WFO Cutting
- 8:27 AM
- Jan 5, 2016
- Mexico NY
Nah, no room for a sump. The room is 6x8 inside and it would be way over kill for the amount of water. Its not flowing water from the joint but enough to wet the floor in a really hard rain. Btw, it's coming from the vertical joint not up through the floor. I'd rather correct the source than fix the symptoms. Sealing the joint just might eliminate it all together. I'm going to try the hydraulic cement first. KISS = Keep It Simple StupidDoes that boiler take up the entire room? If you have the floor space, maybe just put a sump in, next to the wall, and run a small pump.
