Big bore and stroked Husky 395 build.
Redfin
Meh...
11:07 AM
Central Pa
I originally thought of the same thing. I was going to skinny up the weights to be the same size as the 395 and even reduce some of the counterweight near the center of the throw to match the 395 weights. But the big rod end is only 0.010-0.020" less than the counterweight and the case part line is centered over it, so you still end up taking about the same amount off the gasket surface.
Really, it spools up plenty quick. The extra inertia probably helps keep the RPM more stable in the cut.
I was mainly concerned with removing that much material from the 288 case.
Nice work on this one Man.
srcarr52
11:07 AM
Iowa City
It would be the same as what got removed here.
jacob j.
Only the weird
8:07 AM
Coastal Oregon
I have a few 285/298/2100/2101 cases sitting around with no cranks now... I wonder about a 3120 in those?
Mike Rupley built one that apparently turned out real nice...I think he just had to turn down the shoulder of the flywheel side of the crank. I got extra 2100 and 3120 cranks- I'll do some mock-ups this weekend.
mgr1
5:07 PM
Belgium
On the other site a member did a 2100 with 3120 crank.
mgr1
5:07 PM
Belgium
Can post a link if it is allowed.
srcarr52
11:07 AM
Iowa City
Machining the weights and buffing the conrod is all that it needed to put the 3120 crank into a 2100 , even the key line up .
So yes you can also put a 3120 crank into a 288/395 .
Interesting. I guess I'll be on the look out for parts for the next hot rod.
10:07 AM
After seeing some of your stuff.....I'm pretty sure you can make anything work.
