- 5:02 PM
- Jan 14, 2016
- North western Ohio
You can solder an old copper radiator but it takes some practice if you've never done it .Pressure wash all the crude off it .Uses a soft wire brush around the leak and acid flux with 50/50 solder .An acetylene turbo torch works good but a propane bernz o matic type work will work if that's all you have .Just watch you don't get it so hot you pop a seam .Old truck and tractor radiators you'll be doing it quite often .Damned things are old as the hills .40 years of hard water does a number on that copper .
Fact when I changed the radiators on both Georgia's Envoy and my Jeep CJ 5 vintage 1960's I used distilled water with the anti freeze .At 89 cents a gallon it's worth not having an acid condition to get started .
