Best 50-60cc saw
lehman live edge slab
Live Action
10:53 AM
Mn
Here's a 54cc ProMac getting it done with a 24" bar . It was pretty wet out there that day.
Only problem with this saw is you need to buy a supply of mechanic gloves to dampen the vibrations. Also hasn’t been made in how many years? Probably not a saw for heavy constant use anymore.
Woodpecker
Sassy Madam
11:53 AM
I just got a 400 from Harry and Kevin ported it..I've ran it with a 20" bar and it's got power to spare.
I'm not really in to it though, primarily because I can't tell the difference between it and a 462...they feel the same to me..but if you're looking for a saw to run a 20" bar and have the money it's not a bad choice at all.
But the 400 weighs at least 4 big black dildos less than the 462!!!!!😱
sawmikaze
11:53 AM
steeltown
Don't make sense.
It's not popular and bad for the forum, I've found that out 100x over.
Live Action
10:53 AM
Mn
Don't make sense.
I do get the allure of some of the old saws and want some old macs to play with but as much as I like to pull my old 041 non av down ad run it or an 08 for a bit they don’t usually stay out more than a tank and back to a newer saw.
Hundred Acre Wood
Full-time Slacker
11:53 AM
On the hill
Didn't the OP ask which between a 620 Echo and a 562xp Husqvarna or did I miss something?
You missed that we're on an internet forum where the attention span is about 6 seconds. Lol.
Also, his very first words are:
"Looking for opinions on the best 50-60cc saw with a 20 inch bar."
Member
10:53 AM
Followed by...
Thinking of either a echo 620 or husqvarna 562, any opinions would be appreciated.
and...
Looking for new, I should have specified.
Hundred Acre Wood
Full-time Slacker
11:53 AM
On the hill
Followed by...
and...
Agreed. But I interpreted that as meaning "looking for a 50-60cc saw with a 20" bar, here's a couple I found. Are there others I should be considering?"
It seemed to me the OP was open to other ideas and thoughts when he said:
I’ve got a 390xp with a 28” bar and a 660 with a 36”. Just looking for something smaller and lightweight.
Member
10:53 AM
Carry on then.
Maintenance Chief
11:53 AM
South Carolina
All I used for years was a Dome top 10-10 and a Promac700, I still break out the 700 to drop trees for fun.
Ketchup
Epoxy member
9:53 AM
Colorado
I have always been disappointed in 60cc saws. Get a standard carb 261. 620 and 562 are heavy, expensive and not that powerful. You already have two muscle saws. Get a limber with enough grunt to do bore cuts. It’s the one you will use the most.
