- 10:23 AM
- Jan 17, 2016
- Wv
Use the decompHello group, today I went out and took the carb off and took it apart one thing I noticed, I did not put the (what I'll call the float, hinged part that holds the needle valve with a spring) I did have that fork installed incorrectly, I cleaned it out (the carb) I pulled the vent out of the tank took it apart maybe the foam had oil in it but I cleaned it and the foam looked much larger. I was careful to look at the gaskets and see if I did something incorrectly but the holes match up with the carb body. I sprayed the cleaner (brake and carb into the hoses/jets I not at full blast but I saw fluid coming out.
I was 100% sure it would work and hell no, it would only start with starter fluid, or I poured some gas down and it ran and it runs high RPM for 10 sec. then dies.... being a lefty I'm having issues with starting it as I do it from the other side I can't get the right hand to pull correctly anyway, I'm not getting gas flowing it will start on the 3-4 kick then run 3-8 sec. then dies then I cannot start it for a 10 min. but to be honest, I don't have the right muscles or lack of muscles to pull at the speed you need so I'm not sure if I'm just being weak and not able to give it 7-8 strong pulls or if something is still wrong. I'm going to re-read the posts and try to narrow this down. I can't understand how I can hold the throttle wfo and start it when I have to hold the saw with one hand and pull maybe a zip tie which I will try now. I'm not kidding you guys I'm getting really pissed off because I'm not that stupid, and I'm not as weak as it seems in this situation... but damn I don't get this issue. The carb has only 3-4 parts I might go ahead and replace the hoses.... jesus
And are you familiar with drop starting?
