Bearing Replacement Idea
Warped5
11:01 AM
Northwest IN
While chatting with a buddy today, a thought occurred to me .... (REALLY odd for a Sunday)
Many of us have done the 'heat the case halves and drop in the frozen bearings' operation.
Has anyone tried dry ice to chill the bearings?
cus_deluxe
terms of service violator
12:01 PM
Michigan
i do it. gotta think it cant hurt. funny, i talked with an old timer friend of mine a couple days ago. he told me to set bearings on an incandescent light bulb for a while and the install on the crank. more than one way to skin a cat and stuff.
cus_deluxe
12:01 PM
Michigan
i misread teds original post. i dont use dry ice, sorta glossed over that part haha. still cant see it hurting anything
Warped5
11:01 AM
Northwest IN
The buddy I was chatting with worked for Allis Chalmers years ago.
They would freeze valve guides in a freezer (at about zero) prior to installation and would occasionally run into 'difficulties'. One of the engineers suggested using dry ice; he said it made a huge difference.
....so I wondered if anyone around here had tried it.
12:01 PM
As a matter of record years ago the hardened valve seats in Ford 429 V8 engines used liquid nitrogen to shrink the inserts .I suppose you could use a CO2 fire exting1sher and get the same results . Once again another method of skinning the same cat .
Jughead
12:01 PM
in my experience bearings in the freezer has caused me problems.it seems to cool the cases just enough at 275f to cause the bearing to stick halfway.partly i believe is because the bearings start sweating as soon as they hit the warmer air outside of the freezer.for me i've had much better luck with room temp bearings and the cases right at 290-325f.
Warped5
11:01 AM
Northwest IN
During me recent frustrations with my Husky 288 rebuild, I ran into the exact same thing. Kinda 'forced' me to go consult the Service Manual. I had always heated cases to 300 F .... the SM said to heat them to 300 .... Centigrade (about 400 F).
Made all the difference in the world ... bearings literally dropped in.
stihl_head1982
Here long time
12:01 PM
USA
So we are saying room temperature, not "household" freezer works better?
You guys using an oven, heat gun, or map gas torch?
12:01 PM
You can probably do better with a heat gun because you can localize the heat around the bearing pocket .If you bake the case in an oven like so much apple pie the whole dang thing gets hot .Try picking up 400 degrees of aluminum sometime and see how you like it .
Right out of the "book" freeze the bearing heat the cases ,install in the cases .Then use a big soldering iron to heat the inner race ,install the crank .Do likewise on the other side .
I've done it both ways,bearings in the case and bearings on the crank .
On the shaft first couple methods .Bearing heater which I doubt many have including myself .Soldering iron which I have several or heat them up in oil to about 250 degrees .Any method will work .
Whatever you do don't be beating on them with a big ball peen or a brass hammer like trying to drive a railroad spike .
jmssaws
Banneded
11:01 AM
I have put the bearings on the crank and froze all of it and I've put the bearings in the case and froze the crank.
If the case is hot enough it will fall together even with room temp bearings.
I use to be afraid of getting things to hot but I got over that after a hundred or so.
I do lots of bearing jobs for people.
12:01 PM
After thought .Way back when in my teenage juvenile deliquent days we used to cool off cases of beer with a CO2 fire extingisher .That would dang sure freeze a bearing .If you did it too long it would freeze the beer .
