- 10:56 AM
- Apr 28, 2016
- Croatia
5000 Amp out of a under 10 lbs thingamajig?
OK.
Still, false advertisement even on the spec sheet of the posted link, 66000 Joules/5 seconds at 12 Volts is not the claimed 5000 Amps.
It is 1100 Amps, according to Google AI
Used to be able to buy 8v batteries for the 6v system and helped with cold weather quite a bit.I've had 2 Carquest 6V lead/acid batteries last > 10 years in a 1940s Ford tractor that lives outside under a tarp. I'm starting the tractor with one later today to plow the snow we got yesterday. Tractor is original 6V + ground system.
Here is a 5 oF day. Got the radiator covered up.
I can't find any battery comparable today for CCA (870) of the same size that will fit inside the battery compartment. I just shopped the same size for my cousin's 1953 Ford NAA, best I could find was 700 CCA.![]()
Stating 5000A is not a claim to anything--it's just marketing. All I'm arguing is that the only claim the company makes is that the charger will start up to 10L gas & diesel engines. If they claimed 5000A output then that would be a different story. And if you can show me where they make a claim to 5000A output then I will gladly admit I'm wrong, but I haven't seen any such claim.I kinda knew You would counter argue.
Says clearly 5000 Amps on their specification sheet.
Might be a dumb / uninformed question, . . . but, can you hook up some kind of transformer to bring a 12V battery down to 6V?I can't find any battery comparable today for CCA (870) of the same size that will fit inside the battery compartment.
This do that?Might be a dumb / uninformed question, . . . but, can you hook up some kind of transformer to bring a 12V battety down to 6V?
Would that double the CCA rating?
Philbert
There would be some percentage of energy loss in the step down, but probably not a lot.Might be a dumb / uninformed question, . . . but, can you hook up some kind of transformer to bring a 12V battety down to 6V?
Philbert
Claims of enhanced capabilies of just about anything under the sun is an old marketing ploy that for the most part works .My favoite which a lot of people take the bait ,hook, line and sinker is log splitters .Claiming 40 ton capabities with a four inch cylinder and a 6 HP engine and a 3,000 PSI hydraulic pump which is factory set at 2750 PSI .---do the math---
Nice. I still remember seeing the ads for those on the Bazooka Joe bubble gum wrappers.
