Battery Chargers
5:35 PM
5000 Amp out of a under 10 lbs thingamajig?
OK.
Still, false advertisement even on the spec sheet of the posted link, 66000 Joules/5 seconds at 12 Volts is not the claimed 5000 Amps.
It is 1100 Amps, according to Google AI
MtnHaul
8:35 AM
West Coast Mtns.
OK.
Just about every single jump pack made advertises some kind of "peak amps" which are always far more than the power that can be supplied consistently over a meaningful time frame.
If you carefully read all the info related to this specific jump pack there is nothing, absolutely nothing claiming that it delivers 5000 amps. Marketing yes, false marketing no. Deceptive marketing? Sure, but all marketing is deceptive in my opinion. There isn't any info available on what the actual output is, but I do know it will easily start a 7.3L IDI without any batteries installed in the vehicle. The only claim the company seems to make is that it will start gas & diesel engines up to 10 liters. If I had a 10L engine I would go test and make a video.
It is interesting that the company does claim that their largest 12/24 volt model will deliver ". . .over 10,000A of starting power. . ." but none of the other models include that specific language. It's kind of like when Harry Truman gave the okay to drop an atomic bomb the military told him they would be dropping just one bomb of the tested type--but they were also dropping a second bomb of the untested type. The Devil is always in the details.
Edit: How about this one at 5.82lbs, https://static.globalindustrial.com/products/pdf/82455-noco-company/B3085749_SPECS.pdf
5:35 PM
I kinda knew You would counter argue.
Says clearly 5000 Amps on their specification sheet.
lehman live edge slab
Live Action
10:35 AM
Mn
I've had 2 Carquest 6V lead/acid batteries last > 10 years in a 1940s Ford tractor that lives outside under a tarp. I'm starting the tractor with one later today to plow the snow we got yesterday. Tractor is original 6V + ground system.
Here is a 5 oF day. Got the radiator covered up.
I can't find any battery comparable today for CCA (870) of the same size that will fit inside the battery compartment. I just shopped the same size for my cousin's 1953 Ford NAA, best I could find was 700 CCA.:(:(
Used to be able to buy 8v batteries for the 6v system and helped with cold weather quite a bit.
MtnHaul
8:35 AM
West Coast Mtns.
Stating 5000A is not a claim to anything--it's just marketing. All I'm arguing is that the only claim the company makes is that the charger will start up to 10L gas & diesel engines. If they claimed 5000A output then that would be a different story. And if you can show me where they make a claim to 5000A output then I will gladly admit I'm wrong, but I haven't seen any such claim.
I would equate their "5000A" labeling as not much different than a company adding "35% more FREE!" to a package of chips or crackers--they're not saying what they are giving you 35% more of. I would say it's a shady practice but it seems to be a common practice. I have no emotional stake in this, but I am interested in the facts.
And I of course checked and double checked their various "spec sheets" and they don't list anything in terms of actual output. I only bought one because the insurance company was paying for it--I would have never paid out of pocket for that "thingamajig". It does work well though, and hasn't failed me yet.
Philbert
Chainsaw Enthusiast
10:35 AM
East Dakota
Might be a dumb / uninformed question, . . . but, can you hook up some kind of transformer to bring a 12V battery down to 6V?
Would that double the CCA rating?
Philbert
MtnHaul
8:35 AM
West Coast Mtns.
Might be a dumb / uninformed question, . . . but, can you hook up some kind of transformer to bring a 12V battety down to 6V?
Philbert
There would be some percentage of energy loss in the step down, but probably not a lot.
Philbert
Chainsaw Enthusiast
10:35 AM
East Dakota
Will any of those support the cold cranking startup amps for an engine, versus just running electronics?
Thanks.
Philbert
11:35 AM
Claims of enhanced capabilies of just about anything under the sun is an old marketing ploy that for the most part works .My favoite which a lot of people take the bait ,hook, line and sinker is log splitters .Claiming 40 ton capabities with a four inch cylinder and a 6 HP engine and a 3,000 PSI hydraulic pump which is factory set at 2750 PSI .---do the math---
11:35 AM
Regarding voltages on a DC series wound starter motor it goes like this . If you connect 12 volts to a 6 volt motor it multiplies the power output by around 4 times .Conversely if you half the voltage you get about 1/4 the power ..--and that can result in a burned up starter motor . E times I is wattage divided by 746 equals HP .
OnlyStihl
9:35 AM
PNW
So true. And I'm still trying to get my money back. Guaranteed my ass.
ZERO
Simple Life
5:35 PM
Woods & Mountains
To combat imbalanced cells, partial state of charge, and sulfation, I bought this unit. It suits my needs.
Not saying that mine is any better/worse than all the others.
Keeping the car battery topped off in teen weather.
r7000
11:35 AM
CT
My 40+ years old K-Mart charger has served me well. Still works, and great too. But I'm suspicious whether or not it has prematurely killed a few batteries, as it might not be able to properly charge AGM batteries, i.e. overcharging. :thumbsup:
Traditional lead-acid (flooded) battery vs AGM battery has different charging specifics, albeit the same 3-stage bulk/absorption/float stages:
- AGM requires a higher voltage at 14.7 and specifically between 14.6-14.8v to properly fully charge to 100%
- Flooded has a wider tolerant window which can be anything above 13.0v to 14.5v, not going above 14.5 and preferably I think not above 14.2 otherwise you'll boil the water in the [flooded] battery.. and make your basement smell like sulfuric acid and make any cloth/clothing hanging around fall apart after a little while.
- the old kmart charger wouldn't account for the 14.7 higher voltage of AGM and likely undercharge it
- AGM requires lower absorption voltages around 14.2v vs flooded which is then up around 14.7; read about absorption stage this is often tricky and which actually kills any battery if done wrong
- using a Flooded battery smart charger that doesn't know about AGM and using it on an AGM if it does an absorption stage will kill an AGM battery
- the float/maintenance voltage stage for both is around 13.2 to 13.5v
That reminds me. AGMs are a whole lot lighter than flood too.
then you got a cheap battery. no different than a flooded traditional lead-acid battery, if it's lighter than others then you got cheated on lead mass inside which directly relates to battery capacity. AGM internal [lead & sulfuric acid] chemistry is the same as the traditional lead acid battery. my ~2005 DieHard AGM boat battery, still going, weighs a lot more than any you will find at autozone/advance even the optima reds, that was when Diehard AGM was made by Odysee and back then it was over $200. A bettery battery will always weigh more if you acknowledge physics and the density of lead.
So I decided to buy a new one, smart, digital, 10 Amp max - or so the packaging claimed.
It is not what I hoped for.
It will push 10 Amps only when the specific program is manually selected, and it pushes "up to 10 Amps" only for a short period of time with 3 Amps and less prevailing most of its charging cycle.
Talk about false advertising.
It does OK topping of the tractor battery every now & then.
It did fine charging a deep discharged car battery, but took like 10 hours.
you completely misunderstand the charging cycle and limitations of lead acid batteries. False advertising maybe, as they oversold capabilities using tricky wording. But to properly charge a [car] battery it takes at least 8 hours. You can only push 10 amps, and even up to ~50 amps, on the bulk charging phase of the battery which recharges it from 0% up to no more than 80%. From 0% to 50% is when you can do the "boost charge" on those old (or new) cart chargers used in auto shop. When battery is above 80% is when you need to "trickle charge" it maintaing correct voltage as I descibed and reducing amperage down to 2.0 amps or less... which is why you see so many 1.0 and 2.0 amp chargers on the market - they can be small and still do bulk charging it just simply takes longer. **batteryuniversity.com** has good read on the topic.
Philbert
that would be a DC-to-DC "converter" not "transformer. It would be sized to be in the 1hp to 2hp range, for which car/truck starters are rated at 1.0kw and 1.4kw and 1.7kw last I knew for the small to medium sized starters used today up to the 5.7L/350.... the starter on my 2006 8.1L is a 1.7kw. The 6.0L to 7.3L diesels are 3.0 to 4.0kw starters from what google tells me, so you would need a "DC converter" rated for that kind of kw the load would be. If a 1.7kw 12v starter drew 500 amps, then a 6v starter would draw 1000 amps to achieve the same output... it is not a simple watt = volt x current as the starter initial locked rotor draw amperage is very high and there is no electrical resistance when the starter is not spinning at first. After cranking for a few seconds and the initial shock load reduces to constant effort then the starter could maintain its rated 1.7kw (~2,2hp) rating at ~140 amps. So you would need a DC converter to handle those ranges of currents for whatever duty cycle for a engine starter load... google "who makes or sells a 2hp rated 12v to 6v DC converter tolerating 500 amps surge". Otherwise yes there are 12v to 6v DC converters that can handle < 10 amps, called a step down converter... "buck" or "linear". But from a battery's CCA rating perspective that "CCA" rating of the battery would not be affected.
r7000
11:35 AM
CT
Claims of enhanced capabilies of just about anything under the sun is an old marketing ploy that for the most part works .My favorite which a lot of people take the bait ,hook, line and sinker is ...
my favorite was "follow the science" back in 2021.
11:35 AM
A few weeks we got hit with the"Siberian express " .Just flat took the stuffing out of my tractor battery which was a size 27 marine deep cycle 12 volt .It was old anyway but when the temps dropped to below zero and it couldn't cut the mustard .Replaced it with a size 24 due to physical size limitations .Then don't you know the damned old Fergie blowed the ignition condenser and it was too freaken cold to change but in the process I failed to shut off the key .Ran that heavy duty battery down to nothing.When I put the charger on it I thought I had killed it .Took 20 minutes before it even started to charge but came back up,no damage .Had it not been a deep cycle chances are it wouldn't have . That's one reason for my machinery I use deep cycle marine batteries which are often only 10 dollars over a standard car battery.Pot lickers certainly are heavy though
