ATV project
LAWN BOY
Pothole
1:40 PM
Merrill, WI
Working on my 90s Polaris 250 2wd 2 stroke ATV. Used spray carb cleaner to clean the carb today. Throttle response is now good. Idles a bit low. The shifter doesn’t like to go all the way into low or reverse, and when it did, I drove 6 inches before it stopped and squealed like a pig. Google says the belt is probably bad, but idk, here’s pics. Also where exactly should I spray what to test for an engine air leak? This is the first ATV I’ve worked on this much so this is out of my knowledge base. Any help would be greatly appreciated. Thanks for your time.
BTW: clutch cover has 2 tiny cracks and doesn’t seal perfect as you’ll see in one of these pics. And a tube going from clutch cover doesn’t line up perfect with that other tube…
Yukon Stihl
1:40 PM
Great White North
Pressure and Vacuum test same as a chainsaw.
You will have to strip it down to get to the seals if it doesn’t pass the tests
GMB74
4:40 PM
Vermont
Remove the belt and check it for a worn spot. Someone probably got the machine stuck and horsed it trying to get it out, burning a bad spot in the belt. If so, need a new belt.
The clutch covers do not have to fit perfectly for the machine to work, but do need to fit to keep water and dirt off the belt and clutches when running off road. The plastic covers are known for warping with age like the ones in your pictures. Replace them if they are still available or figure out a way to cobb them up to seal the best way you can.
As Yukon Stihl says, fabricate some block-off plates and P/V test just like a chain saw.
Loony661
462’s 4-LIFE
3:40 PM
Winona County, MN
If you want to test with carb spray, you need to let it idle, and then give short blasts along the cylinder base, as well as along the crank seals. If there’s a change in RPM when you spray (or very shortly after) you’ve likely found an air leak. Another place that likes to fail, is the carb boot. They dry rot and start sucking air after the carb, leaning the mixture out.
fossil
4:40 PM
Ontario, Canada
You need to find the minimum width spec on the belt to see if it's worn too small.
LAWN BOY
Pothole
1:40 PM
Merrill, WI
The ATV has decided to start running and driving better without me doing anything. It occasionally acts up like stops driving or it got boggy once, but I've been ripping around on it for the past 3 days and it usually runs and drives fine. One time when I put it in drive and then git on the gas it acted like it was in neutral but there was also a very weird loud whistling noise, after letting of the gas and letting it sit a couple seconds it was just fine and drove. Anyone in Wisconsin have a seat and rear fenders available for it? I have an offer to trade it for a fully operational Yamaha snowblower on tracks...
full chizel
¯\_(ツ)_/¯
4:40 PM
USofA
Cool you can give more blow jobs
