LAWN BOY
Pothole
- 8:54 AM
- Feb 27, 2024
- Merrill, WI
Working on my 90s Polaris 250 2wd 2 stroke ATV. Used spray carb cleaner to clean the carb today. Throttle response is now good. Idles a bit low. The shifter doesn’t like to go all the way into low or reverse, and when it did, I drove 6 inches before it stopped and squealed like a pig. Google says the belt is probably bad, but idk, here’s pics. Also where exactly should I spray what to test for an engine air leak? This is the first ATV I’ve worked on this much so this is out of my knowledge base. Any help would be greatly appreciated. Thanks for your time.
BTW: clutch cover has 2 tiny cracks and doesn’t seal perfect as you’ll see in one of these pics. And a tube going from clutch cover doesn’t line up perfect with that other tube…
