Any Chinese chainsaw and chinese parts discussion
Poleman
10:19 PM
Rapid City,S.D.
Just a FYI, on mine, my coil was bad out of the box I had extras so put a new one I had it and it came to life. Had a slight problem like yours also Leafy but the different coil adjusted right up where it should be. Wondering if your coil was mfg late before they started Holiday???? Kinda figure that’s why mine was off and bad!!!! Lol
12:19 AM
It may have been the heat that got mine
Near 100
And long blocking cuts
A few loggers told me that's what did theirs in.
A few guy's had multiple failures.
But oem coils are pricey so he
Keeps buying am.
The first one lasted more than a year
Not bad.
Huztl lasted seconds
Idles good though lol
Leafy
12:19 AM
NH
Mine looked like it might have been the coil for the small diameter flywheel as well as sucking
12:19 AM
First time I've seen this
Clutch type bearing oversized
Used as a wrist pin bearing
Oem on top can't use it.
Been in many of these none were like this.20180618_204203.jpg 20180618_195029.jpg
Member
11:19 PM
Been in many of these none were like this.View attachment 129181 View attachment 129182
As long as the bearing will fit inside the piston it will be fine if it sticks out the sides of the connecting rod. It will center itself up and run along just fine. (Assuming you are changing the piston) Should catch oil really good. :)
12:19 AM
It has a rather loud clunking noise
With the 372 oem bearing in place
Hoping to find a oem bearing that will fit in the oversized crank
Leafy
12:19 AM
NH
Pro tip. HL Supply does sell a 372 coil but its not listed in the 372 part section. They only have a 272 coil in the 372 section so dont just blindly trust their website to be correct. If you do need the 372 coild from them you have to just search for it.
12:19 AM
Price?
Termitebuffet
Home of the corn can muffler .....
12:19 AM
Midgetville Norf Kacolacky
smokey7
12:19 AM
Detroit
If your clone jugs were running well why would you switch to oem? Can you show some cylinder pics of your used clone jugs? How were they wearing? I have seen some flake the plating like tin foil.
12:19 AM
This is that big bore has 4 year's on it.
20171108_172651.jpg 20171108_171447.jpg 20171108_172643.jpg 20171108_172531.jpg No plating issue's cheapest ebay whitebox at the time.
Just needed rings but he wanted
It rebuilt like my first saw 50mm with a 268.
I always check port edges and relieve them.
But of course there's been a lot of bad plating jobs.
