bigbadbob
- 10:00 AM
- Jan 9, 2016
- Interior BC Canada
I have the same as this,, fixed leads,, it was a promotion bout 1980,, the newer model had removable leads
Dam its been a good welder,,
Why in the hell would you do that?If you say so...
Removing the casing/shell and unbolting the leads from within, is not "removeable" in my book.
What’s the heaviest gauge steel you’ll be welding?
A 30 amp 220v breaker I use often has never tripped stick welding 1/4 plate, Can't remember the setting and rod size.I've no idea. Heaviest yet is ~3/4" rebar. The Century AC230 tackled it with no problem. Next was chain hooks on my neighbors Kubota front loader.
Yeh, believe 1/8 7018 is what I've used mostly. Always on DC with a Miller Thunderbolt XL. Run it and see what happens. If you're a reasonable distance from the panel it should do fine if it isn't turned up too high.Owner says he's welded with 1/8 rod with no problem. I have with my Century AC230 also use 1/8. I think it was overkill for what I welded. What I know the next size up is 5/16th. From what I have experienced it is with 7018 that I might have to use more power. I was max on the Century and could not get it to burn the 7018 (maybe 1/8, but I don't remember). But with this new machine and the DC setting, the 7018 is probably a lot more compliant.
I'm starting to like the idea of this new Lincoln and the long leads. At 350lbs it can sit in one spot and the leads will reach as far as I'll ever need. I can almost sell the Century and pay for the Lincoln. At $300 it will be a daylight robbery with a willing victim.![]()
#1 In my lifetime I have never set a SMAW machine at 200 amp to use on 1/8 stick...........................My understanding of this is at 230V outlet I'd need a 70Amp breaker to run it at 200A/28V. Is that right? With my 50Amp breaker the panel says it will draw 48Amp to run it at 140A/26V. Right? To get full use of the welder I'd need at least 86A. I don't even know if the utility company supplies my area with that much juice.
For reference I have had my Century AC230 at full power with no problems, (again) with my 50Amp breaker.
Having grown up using an old Forney and than a Lincoln stick welder I wouldn't go back to the transformer style for light duty stuff the cheap little inverter ones you can get for around 100 bucks are way better with hot start and arc force options but at the same time they are made for the lighter duty end of stick welding 200amps and below at 220volts. Most of my welding things days is all Mig but I still have that little arc welder just incase, it's nuts how small and light those new little inverter ones are could probably fit in my lunch box.
