Another MS290 Rebuild Thread
11:29 AM
I used FT in mine, and I won't say it was the strongest runner, but it ran ... good. I won't endorse their P&Cs across the board, but for this particular model, I think they do well, I got a lot of feed back from others before I went with it.
FYI, I used their P&C, rings, clips, and seals. Also did a muff mod & timing advance. The guy using it wants to buy it.
94BULLITT
11:29 AM
VA
I wonder if it was slapping a bit... Did it sound "off" before it grenaded?
I thought the same too. It always turned over easy and it did not make any noise. I tried holding the piston on the same angle as what it runs in the cylinder and it looked like it had enough clearance. I need to see if I can find the old piston in my scrap container and compare it to the new one again.
Sent from my SPH-L710 using Tapatalk
94BULLITT
11:29 AM
VA
Well my new cylinder came today from China. I going to order one from the US for $35 but it was sold out when I went to order it. I ordered this cylinder from machine doctor. I also ordered a Cross Piston to put in it, mainly because it come with caber rings. It was not that much more for a piston than just a set of rings. I keep forgetting to see if I can find my OEM piston in scrap bin to compare to the AM piston.
I put the degree wheel on it and got some numbers.
INT-161
EXH-162
BDWN-27
I can't remember what the transfer was. I'll get some pics of the cylinder tomorrow too.
94BULLITT
11:29 AM
VA
I looked for the OEM piston and I could not find it.
Here are pics of the new cylinder
94BULLITT
11:29 AM
VA
I forgot to post these pics before. I think I found out what happened to the original cylinder. The carb inlet was packed full saw dust.
94BULLITT
11:29 AM
VA
Here are pics of the cylinder before it went on.
I put it together and vac tested it and it was good so I finished assembling it. I also put an 044 carb on it temporarily and a my modded muffler of my 039. I'll mod the muffler on this saw later.
94BULLITT
11:29 AM
VA
I started it up and let it idle and revved it a few times then shut it off and brought it back in and checked the compression. It had 135psi. The previous piston/cylinder never got above 125psi. The Chinese rings feels so cheap and brittle. The Caber rings have a better feel to them and I think they were even easier to install. I'm not using any more Chinese rings.
Lightning Performance
11:29 AM
East of Philly
Have yet to see someone have this many problems getting a 290 going. What is the plan for the saws use?
Those pistons and rings are junk and they are the problem. That first jug looked kinda so so.
94BULLITT
11:29 AM
VA
What are are you talking about problems????? The Chinese piston flew to pieces.
11:29 AM
Saw looks good, but please do me a favor, wear boots when you cut! Even if you are careful with the saw, sooner or later a round will end up on your foot, and those sneaks will not help! I ALWAYS have boots, gloves, eyes & ears. Just a good habit.
11:29 AM
East of Philly
I was just wondering if was your firewood saw. If so I was going to offer parts and help if needed. Just, never mind.
94BULLITT
11:29 AM
VA
Thanks, Mike. I just wanted to make a quick video of it today. I usually have steel toe boots on when I cut.
