Redfin
Meh...
- 2:26 AM
- Dec 24, 2015
- Central Pa
Is there any success in trying to reseat a leaking welch?
What psi should it pop at?
More importantly check that it holds 10 psi, and if you tap the lever it re-seats without leaking.
It can vary carb to carb on the same model usually 5-20psi but the exact number or target is not the point, more the fact that it does pop off or not is my understanding. Its quite un natural to put 20-30 psi through the carb and damge can result to diaphrams etc.What psi should it pop at?
That's a pretty impressive leak on the carb, obviously there is pressure in the tank. So what kind of tank vent does it have? Is it just a duck-bill or maybe it is completely plugged?
I'm not a big fan of EPA approved tank vents. Mine tend to get gutted so the tank is vented to atmospheric pressure. Then I know the fuel delivery to the carb is consistent, instead of pressurized one time and a vacuum the next.
there no regular screw they are a grub screwOn my 365BB I removed the duck-bill valve and packed the inside with steel wool. The vent does leak when I am putting fuel in the tank, perhaps around 1/2 teaspoon of fuel. It will stop leaking as soon as I get the fuel cap on. The bit of fuel leaking through the vent makes it a 'self-cleaning' vent.
I didn't have to gut the vent on the 029, it was already just a piece of hose with a screw on top.
I don't know how that vent on your saw works. It looks like it is just a hooked piece of pipe with a filter element around it. Is there a valve in there somewhere that can cause the tank to pressurize?
Your issue may certainly be heat. You like comp and timing advance, I do too. But the saw leans as the head heats up.I've yet to have a carb on mine that wouldn't run out of fuel on a long cut so I'm all ears to deeter.
I've tried drilling every hole i can drill without success.
You seem to have found your issue, but as you likely know, I had that problem on an 026 because of the timing advance. The advance made it wanna be super rich to get the idle down. Then it would pool fuel and die when I hit it, but only after a period of time idling.
Ok, only thing I did is lower the metering arm to sit flush. It seems to sound a little better coming out of the cut and doesn't race before returning to an idle.
But after it idles for a bit and you blip the throttle it bogs. It died the last time when I blipped the throttle.
I checked rpm and I was 13,850 let it idle for 5-6 seconds and hit the throttle and it died.
You seem to have found your issue said:I never had an issue before so I doubt mine is the timing. I did however take my 046 too far with timing and have the same problem as you did. I dialed it back and it defiantly was the problem
Pics?I just got a set of Kool carb punches for that.
