All Things 288XP
quattro90
11:08 PM
Central Indiana
Got the new K&S top end on the 288XP Lite. Squish w/o gasket was .022" and timing # 120* 100* 75* took the intake to 78* and left everything else alone. Put a carb kit in the Tilly and got her back together. Went to the woodpile to cut and make some cookies and put a few cuts on video. Sheared the flywheel key in the first 1" of wood. Another week of waiting begins........
quattro90
11:08 PM
Central Indiana
In the end I did wait for the keys to arrive so I could have both a shaved key and the added security of a lapped flywheel. I did lap the flywheel with the compound to make sure it stayed put. Torqued it down to spec and that’s what she sounds like as a happy fatly tuned for break-in later this weekend. 7A65CA4D-0F2E-4733-B758-1322CCE1E80F.jpeg
JonCT
11:08 PM
CT
I know it’s not a 288...but close.
PA Dan
FYD
11:08 PM
White Oak PA
Hey John does your 288 have the small hole in the oil pump and used the small worm gear? If so there is a ring that pops out so you can run the larger updated worm gear. I cant help with the wire question! Hope this helps!
