All Things 288XP
mortalitool
aka Nick Stoeckel
10:46 PM
Lexington, MN
The blue adapter piece for the big k&n is sort of a hard part to find. So I made some up myself! I can make more if any if you guys want one
Sent from my SM-G935P using Tapatalk
XP_Slinger
They’re Just Saws
10:46 PM
Central NY
Very nice work. Is the K&N better to run than the original high top filter?
beaglebriar
The Peanut Gallery
10:46 PM
Warren Center, PA
K&N will flow better but you have to oil it. That's a turn off for me. You can forget about tapping it clean.
There is the filter wrap that goes along with them but that's more screwing around than I wanna mess with on a chainsaw.
If they make one that doesn't need oil I might try it.
XP_Slinger
They’re Just Saws
10:46 PM
Central NY
I’ve had K&N filters in some other toys, not a fan of the cleaning & oiling either. I’m gonna stick with the factory filter
JonCraig
9:46 PM
Tennessee
Never tried one on a saw, but have had 4 in cars as I recall. I buy the drop-in OEM one, which can usually be found for $30-ish on eBay/Amazon/whatever. I’m on my second bottles of cleaner/oil in 20 years. That works out to ~$35 per car. If you guess $10 per paper air filter at a parts store (and some are waaayyy more...), the K&N paid for itself on the 4th paper filter I would have bought. So 60-100k miles and I’ve broken even. Past that I’m coming out ahead. I’m the type who buys a car at over 40k miles and drives the wheels off a car, so if I don’t get to 200, 225, I consider it a turd.
What were we talking about again?
Oh yeah........... 288’s!!!
mortalitool
aka Nick Stoeckel
10:46 PM
Lexington, MN
Here is my 181se thin ringer....
I will be posting it in the for sale section, but wanted to drop it here because it relates to the topic.
Hate to sell this one, but its gotta go down the road.
smokey7
10:46 PM
Detroit
Were all 181s thin ring and 52mm? What about 281s are they all thin ring and 52mm also? I sware ive seen 281s being t4mm and reg 1.5mm rings.
srcarr52
10:46 PM
Iowa City
181- 52mm, dual thin rings, full skirt piston windowed piston, Gilardoni cylinder.
281 - 52mm, single 1.5mm thick ring, conventional T pin support piston, Mahle cylinder.
288 - 54mm, single 1.5mm thick ring, conventional T pin support piston, Mahle cylinder.
mortalitool
aka Nick Stoeckel
10:46 PM
Lexington, MN
Good info here!!
