PA Dan
- 10:03 AM
- Dec 28, 2015
- White Oak PA
Clutch spring was shot on that saw. Wonder with the new clutch and drum if it will do the same thing...
Very nice work. Is the K&N better to run than the original high top filter?The blue adapter piece for the big k&n is sort of a hard part to find. So I made some up myself! I can make more if any if you guys want one![]()
Sent from my SM-G935P using Tapatalk
I would say yes. It flows more air, and no fines get through. That adapter is for the eliminator set up.Very nice work. Is the K&N better to run than the original high top filter?
I’ve had K&N filters in some other toys, not a fan of the cleaning & oiling either. I’m gonna stick with the factory filterK&N will flow better but you have to oil it. That's a turn off for me. You can forget about tapping it clean.
There is the filter wrap that goes along with them but that's more screwing around than I wanna mess with on a chainsaw.
If they make one that doesn't need oil I might try it.
Howdy stranger, how are you doing Dale?HOORAY 288!!!
Were all 181s thin ring and 52mm? What about 281s are they all thin ring and 52mm also? I sware ive seen 281s being t4mm and reg 1.5mm rings.
Good info here!!181- 52mm, dual thin rings, full skirt piston windowed piston, Gilardoni cylinder.
281 - 52mm, single 1.5mm thick ring, conventional T pin support piston, Mahle cylinder.
288 - 54mm, single 1.5mm thick ring, conventional T pin support piston, Mahle cylinder.
And builds a mean saw in all of the above...like everything else he builds.Scarr knows his 181/281/288s!!
