T.Roller
- 1:02 PM
- May 11, 2016
- Southeast, TN
You have to grind the wall the block rests onScratch that.... partition wall looks pretty flexible.
That's what I was thinking. This one doesn't look like that's been done.You have to grind the wall the block rests on
That would definitely cause an air leak.That's what I was thinking. This one doesn't look like that's been done.
Fo sho...That would definitely cause an air leak.
BruhFo sho...
Thanks Dave... definitely hasn't been done to this one.Bruh
Yes sir it is.Thanks Dave... definitely hasn't been done to this one.
I'm sure that will solve the problem. I haven't had a bar on the saw yet just wanted to check everything over first. Guess it's a good thing I did...![]()
You may have to trim the case I thought you were talking about in side the crank case sorry you may also have to trim the bracket on the elbow a bit.Scratch that.... partition wall looks pretty flexible.
Great find! Looking forward to seeing it doneJust caught up on this entire thread; I am inspired!
Picked up a 1997 288xp Lite last night. Runs and cuts/oils, going to be a overhaul and slight mod. Nothing crazy.
View attachment 130813 View attachment 130814 View attachment 130815 View attachment 130816 View attachment 130817
Yep I was just looking at that elbow thinking the same thing.You may have to trim the case I thought you were talking about in side the crank case sorry you may also have to trim the bracket on the elbow a bit.
Got the 288 my buddy gave to me last week rebuilt. Previous owner had gasket sealer on all the carb connections. Had a heck of a time getting the screws out. Need to get a few fuel lines...fuel and oil tank on this was completely disgusting!!
Cleaned up a bit...
View attachment 130833 View attachment 130834 View attachment 130835
Does it have the K&N set up?Got the 288 my buddy gave to me last week rebuilt. Previous owner had gasket sealer on all the carb connections. Had a heck of a time getting the screws out. Need to get a few fuel lines...fuel and oil tank on this was completely disgusting!!
Cleaned up a bit...
