All Things 288XP
smokey7
6:50 PM
Detroit
@rattler very nice machine work on the jug. Looks like you have your speed and feed all figured out. Very very clean work. Are you using hss dimond insert or carbide? I am so impressed how the finish looks on the band. My bands are true and flat but I definatly have tooling marks compared to yours.
rattler
6:50 PM
NC
I use Carbide inserts that one is not tin coated but the next ones are mine are smoother if I spin faster this just the speed I like. Thank you for the kind words we try hard.
Mike
rattler
6:50 PM
NC
srcarr52
6:50 PM
Iowa City
Mike
For aluminum the inserts are usually polished, no coating and have high take.
p61 western
Ol Mudflap
3:50 PM
GFY
beaglebriar
The Peanut Gallery
6:50 PM
Warren Center, PA
I cut the extension on the cylinder that's it.View attachment 130823
My carb/intake block isn't lining up with the cylinder flange when the cylinder is bolted down. I thought it might cause an air leak if I loosen the cylinder then tighten the carb bolts etc.
I'm thinking tension on the intake block?? This saw a has had tunability issues before I got it.
