- 7:01 PM
- Jun 5, 2016
- Northwoods of Wisconsin
I see you didn't care for my top cover.
I have some green paint......and I need a green one
Hi tops are more better esp in this dustI see you didn't care for my top cover.![]()
not until you start putting weird acid flashback subliminal messaging in your youtube vids. Brother.I guess I’m BBR Jr
You mean David Wyby Special, I've never seen that saw before.Good to see you around again @Onan18
Bar from @how57, 30”, perfect for my height. Fit with adapters, chain just needs a couple links added to fit and be 98dl same as my other 30” bar. Put opener muffler on. This setup is Lowd. Snap crackle pop. Stump Shot Special.
I don't see any wood screws in it?
Wrong! The back AV had one in it.I don't see any wood screws in it?
Not that ugly.
Early models had both an inside and outside steel bar pad, later models had just the inner one.Brand new clutch cover
had to add those brass washers to keep the nut from rubbing. Drum still rubs on the brake band.
What gives?
Fanks
View attachment 471767View attachment 471768
Ernie had an issue with this. Turned out to be an early model trying to use newer model parts. There are differencesI think I see the bar pads present, the clutch however appears to be out too far as in something is holding it back from going in all the way.
Sounds right, mixing them doesn't work, they have to be all the same as I recall.Ernie had an issue with this. Turned out to be an early model trying to use newer model parts. There are differences
I had to grind that little bit off the drum that protrudes out past the clutch and it worked out .
Yes and over the decades a variety of thicknesses of bar's had caused rubbingEarly models had both an inside and outside steel bar pad, later models had just the inner one.
