All Things 288XP
Woodwackr
1:31 PM
ID
Maybe it's the way the picture is taken but it looks like your clutch is actually protruding outside the drum...can you confirm that ?
Maybe I can grind more off of mine 🤔
Ernie
Any grinding should be to the other side, imo.
What is the height of the protruding section?
I took a pic of the distance between the drum and the oiler. What is yours?
Clutch shoes may be slightly proud but the nut portion sticks out nearly 1/4”
davidwyby
Rural desert logging
12:31 PM
Extreme Southeast CA
Probably has to do with the drive worm height too. I’d check that and crank stick out. Don’t have a clutch off a saw, didn’t have time
qurotro
Cookie Cutter
2:31 PM
Ar
I guess it’s the end of the debate ;)
The Chinese *f-worded up. The one with no rust is chincom. Only the chincom one is higher when put on a flat glass. The Oregon 28094X is the same as OEM in every way.BCBA1491-21D3-43A0-BE2E-155559DA20C6.jpeg64977013-C449-4121-9C89-ADCC82A59914.jpeg
qurotro
Cookie Cutter
2:31 PM
Ar
I took mine apart to investigate. The same old style set up. The 2101 clutch drum on mine is still bigger lol..708B0FBD-C16D-4CC9-A03F-54E60CE03561.jpegCD21D519-5D21-4B14-87C9-A89EF2628C73.jpeg
ErnieG
3:31 PM
Northeast PA
The Chinese *f-worded up. The one with no rust is chincom. Only the chincom one is higher when put on a flat glass. The Oregon 28094X is the same as OEM in every way.View attachment 452183View attachment 452182
That definitely explains it rite there ...I had a feeling that was the problem.
I'm gonna find an OEM or Oregon drum .
Thanks for the help
Ernie
ErnieG
3:31 PM
Northeast PA
Is there a good place to get that outer plastic seal part# 501598201 ?
ErnieG
3:31 PM
Northeast PA
But, does it really serve much purpose?
From what I can tell is the inner rubber seal attaches to that plastic outer piece and is pressed up against the metal ring by the drum to keep saw dust out of the worm/oiler .
Just my theory...maybe it's NOT really needed .
Ernie
