- 10:36 AM
- Jan 12, 2021
- Northeast PA
The black rubber piece is sealing the metal ring, not inside the brown dust shield. But I don’t remember which side of the rubber ring goes.This doesn't seem rite either ....does the rubber ring go inside the brown plastic cap ?
Nope still the same ...That looks better. Does the drum seat ok?
Sorry, forgot to measureNope still the same ...
I think the black dust seal goes behind the drown plastic cover instead of inside of it as srcarr52 said .
I have to change it yet but I don't think that's going to matter because the drum only goes in as far as the worm gear either way .
I really think the AM drum/clutch is to big .
Bummer. Get measurements. I’ll measure what I have here.Nope still the same ...
No 2101 clutch drum! Way bigger than the 288s.Bummer. Get measurements. I’ll measure what I have here.
I wonder if you need a 54 02 as shown in that schematic.
Might need to modify that drum with a grinder
Looks like an Ore 22132 drum![]()
Husqvarna 2100 CD Chainsaw complete clutch
Complete clutch assembly with clutch mechanism, with drum bearing, dust seal and rim sprocket. 501 67 52-01, 501 54 02-01 In good used shape with new 3/8 rim sprocket Fits Husqvarna 2100, 2100CD, 2100 cd, 2101, 298xp and otherschainsawr.com
Husqvarna Oregon 22132 Power Mate Clutch Drum Hub 7 Tooth Sprocket With Bearing for sale online | eBay
Find many great new & used options and get the best deals for Husqvarna Oregon 22132 Power Mate Clutch Drum Hub 7 Tooth Sprocket With Bearing at the best online prices at eBay! Free shipping for many products!www.ebay.com
Pt# is from the ipl . He has the early 288No 2101 clutch drum! Way bigger than the 288s.
But you can order 395s they are the same. Actually my 2101 use 395 clutch and drum cuz someone burn up the original one.
Nope from factory. 2100’s is bigger from factory but you can fit 288’s on it. Clutch part number is 1 digit away.181/281/288/285/394/395/298/1100/2100/2101 all use the same clutch drum and can even use the same clutch.
There are 2 different clutch assemblies for these.Nope from factory. 2100’s is bigger from factory but you can fit 288’s on it. Clutch part number is 1 digit away.
Well I tried grinding the drum down but it still hits the cover .
I took it down so the drum and clutch are flush on the outside when installed.
An overall measurement on mine is 35mm side to side
If someone can give me a measurement of there drum I'd know for sure this one isn't rite and I can find the correct one .
Thanks
Ernie
Maybe it's the way the picture is taken but it looks like your clutch is actually protruding outside the drum...can you confirm that ?
